Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] generation IllegalStateException(java.lang.IllegalStateException: Exception while merging and saving source file in sourcemerger)
[Texo] generation IllegalStateException [message #1622438] Wed, 18 February 2015 08:54 Go to next message
I created a single Class in my test ecore and it throws an IllegalStateException when I select the Texo "Generate Model Code". I am using Kepler SR2 on OSX with a 64bit JVM V1.7.0_67. I attach the simple ecore and the stacktrace. The ecore looks fine not sure what the cause is for such a simple ecore model.
Texo version:
EMFT Texo (Incubation) 0.9.0.v201501182340 org.eclipse.emf.texo.feature.group Eclipse Modeling Project
Here is the root cause.
at org.eclipse.emf.texo.generator.SourceMerger.merge(SourceMerger.java:85)
at org.eclipse.emf.texo.generator.MergingOutputHandler.beforeWriteAndClose(MergingOutputHandler.java:63)
at org.eclipse.xpand2.output.Outlet.beforeWriteAndClose(Outlet.java:98)
at org.eclipse.xpand2.output.FileHandleImpl.writeAndClose(FileHandleImpl.java:135)
at org.eclipse.xpand2.output.OutputImpl.closeFile(OutputImpl.java:171)
at org.eclipse.emf.texo.generator.ArtifactGenerator.run(ArtifactGenerator.java:99)
... 9 more
Caused by: java.lang.IllegalArgumentException
at org.eclipse.jdt.core.dom.ASTParser.<init>(ASTParser.java:226)
at org.eclipse.jdt.core.dom.ASTParser.newParser(ASTParser.java:125)
at org.eclipse.emf.texo.generator.ImportResolver.setSource(ImportResolver.java:482)
at org.eclipse.emf.texo.generator.SourceMerger.organizeImports(SourceMerger.java:147)
at org.eclipse.emf.texo.generator.SourceMerger.merge(SourceMerger.java:77)
... 14 more
[Updated on: Wed, 18 February 2015 09:01] by Moderator
Re: [Texo] generation IllegalStateException [message #1622472 is a reply to message #1622438] Wed, 18 February 2015 09:21 Go to previous messageGo to next message
Hi David,
Texo is now being build against Luna. I tested your ecore and it works fine in Luna. Can you try it in Luna?
I will check it if/what I can change to make it work on Kepler again...
gr. Martin
> ... 9 more
> ... 14 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] generation IllegalStateException [message #1622540 is a reply to message #1622472] Wed, 18 February 2015 10:24 Go to previous messageGo to next message
I spend some time on this, I published a new build which should work also in Kepler. Let me know if you encounter any
issues.
gr. Martin
On 18-02-15 15:21, Martin Taal wrote:
> Hi David,
> gr. Martin
>> ... 9 more
>> ... 14 more
The Netherlands
Re: [Texo] generation IllegalStateException [message #1623848 is a reply to message #1622540] Thu, 19 February 2015 06:13 Go to previous messageGo to next message
Thank you Martin,
It work well now.
I had realised and started the upgrade to Luna, but it takes a long time to source and install all the plugins for a new version when you use a lot of plugins. Pity there is not an analysis of your plugins for an Eclipse version and an export, which then can trigger an import on the new version of Eclipse installed which works out what version of all of those plugins are need to install in the new version of Eclipse.
Re: [Texo] generation IllegalStateException [message #1623934 is a reply to message #1623848] Thu, 19 February 2015 07:32 Go to previous message
Yeah I have the same thing when upgrading, I have a txt document with all the update sites I need to visit to get a new
eclipse up and running...
gr. Martin
On 19-02-15 12:13, David Wynter wrote:
> Thank you Martin,
> It work well now.
The Netherlands
Previous Topic:[Teneo] Initialize HbEntityDataStory correctly with MetaModel
Next Topic:[blueprints-emf] Question about generating models for blueprint and Jboss Errai
Current Time: Wed Jul 30 21:24:05 EDT 2025
Powered by FUDForum. Page generated in 0.06893 seconds
