Selection in outline view and editor [message #162214] |
Mon, 20 December 2004 11:21  |
Originally posted by: marlu942.student.liu.se
Hi fellow GEFers,
All GEF example applications with an outline view, that I have seen, has
synkronisation beween the outline view and the editor when it comes to
selections.
When I select a entity in the outline view in my application the
property view gets an event and updates but not the editor. And when I
select a entity in the editor the property view gets updated but the
corresponding entity in the outline view is not selected.
Anyone got any idea what the problem might be?
Marcus Ludvigson
Re: Selection in outline view and editor [message #162657 is a reply to message #162301] |
Thu, 23 December 2004 03:11   |
Unfortunately I have in "public void createControl(Composite parent)":
editor.getSelectionSynchronizer().addViewer(getViewer());
and in dispose():
editor.getSelectionSynchronizer().removeViewer(getViewer());
but still no simultaneous selection in the editor and outline view.
Thank you for your input though. Do you have some advice on how to debug
a issue like this?
Marcus Ludvigson
Pratik Shah wrote:
> In particular, you want to look at the methods hookOutlineViewer() and
> unhookOutlineViewer(), where the outline viewer is being added to/removed
> from the SelectionSynchronizer.
> "Alain Origlia" <alain.origlia@impika.com> wrote in message
> news:cq70hf$7n1$1@www.eclipse.org...
>>Hi Marcus,
>>see the OutlinePage inline class of the LogicEditor class (LogicDesigner
>>example) or the ShapesEditorOutlinePage inline class of the ShapesEditor
>>class (Shapes example).
>>"Marcus Ludvigson" <marlu942@student.liu.se> a écrit dans le message de
>>news:cq6u65$urd$1@www.eclipse.org...
>>>Hi fellow GEFers,
>>>selections.
>>>Regards,
>>>Marcus Ludvigson
Re: Selection in outline view and editor [message #162696 is a reply to message #162657] |
Thu, 23 December 2004 14:07   |
Your graphical viewer is being added to the selection synchronizer too,
right? It happens, by default, in GraphicalEditor#hookGraphicalViewer(), so
make sure that you're invoking the super method in case you're overriding
that method. Set a breakpoint in
SelectionSynchronizer#selectionChanged(...) to ensure that both the viewers
have been added and that that method is getting invoked. If everything's
set up right, you can just step into that method to see why the selection is
not synchronized.
"Marcus Ludvigson" <marlu942@student.liu.se> wrote in message
news:cqdujv$pu5$1@www.eclipse.org...
> and in dispose():
> a issue like this?
> Regards,
> Marcus Ludvigson
to/removed
> >>Hi Marcus,
Re: Selection in outline view and editor [message #162762 is a reply to message #162696] |
Mon, 27 December 2004 10:26  |
Thank you for your help.
I found out that the error layed in the mapping between the different
EditParts. My model does not cache modelchildren because persistence is
done in a DB, so two different getChildren on a model instance results
in different child model instances which made it impossible to map model
to editparts.
A cache, in the outline tree, of model children helped.
Marcus Ludvigson
> not synchronized.
>>Hi,
>>and in dispose():
>> a issue like this?
>>Regards,
>>Marcus Ludvigson
> to/removed
>>>>Hi Marcus,
>>>>>Hi fellow GEFers,
> has
>>>>>selections.
>>>>>Regards,
>>>>>Marcus Ludvigson
FUDForum. Page generated in 0.04490 seconds
