[CDO] custom data type/Class cast exception on notification [message #1619129] |
Mon, 16 February 2015 06:01  |
Hi.
1) I have created an ecore model where I have defined a custom data type :
->MyDouble :
- Default Value : 0.0
- Instance Type Name : double
- Name : MyDouble
- Serializable : true
-->ExtendedMetaData
- References :
- Source : http:///org.eclipse/emf/ecore/util/ExtendedMetaData
----> baseType
- Key : baseType
- Value : http://www.w3.org/2001/XMLSchema#double
2) I have created an attribut in the same model and I have applied this custom datatype to it
3) I Have create an application with CDO. The client just display the value of the attribut.
4) On the server side I change the value the attribut.
On the client side , during the notification I got the following exception :
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Number
at org.eclipse.emf.internal.cdo.object.CDONotificationBuilder.createPrimitiveNotification(CDONotificationBuilder.java:353)
at org.eclipse.emf.internal.cdo.object.CDONotificationBuilder.createNotification(CDONotificationBuilder.java:312)
at org.eclipse.emf.internal.cdo.object.CDONotificationBuilder.visit(CDONotificationBuilder.java:167)
at org.eclipse.emf.cdo.internal.common.revision.delta.CDOSetFeatureDeltaImpl.accept(CDOSetFeatureDeltaImpl.java:74)
at org.eclipse.emf.cdo.internal.common.revision.delta.CDORevisionDeltaImpl.accept(CDORevisionDeltaImpl.java:359)
at org.eclipse.emf.cdo.internal.common.revision.delta.CDORevisionDeltaImpl.accept(CDORevisionDeltaImpl.java:349)
at org.eclipse.emf.internal.cdo.object.CDONotificationBuilder.buildNotification(CDONotificationBuilder.java:91)
at org.eclipse.emf.internal.cdo.view.CDOViewImpl.sendDeltaNotifications(CDOViewImpl.java:1013)
at org.eclipse.emf.internal.cdo.view.CDOViewImpl.doInvalidate(CDOViewImpl.java:879)
at org.eclipse.emf.internal.cdo.view.CDOViewImpl$InvalidationRunnable.run(CDOViewImpl.java:1710)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:26)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:1)
at org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWorker.java:78)
at org.eclipse.net4j.util.concurrent.QueueWorker.work(QueueWorker.java:70)
at org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Worker.java:209)
Re: [CDO] custom data type/Class cast exception on notification [message #1619179 is a reply to message #1619166] |
Mon, 16 February 2015 06:40   |
Am 16.02.2015 um 12:30 schrieb David Ponzo:
> Hi Eike, thank for this quick reply.
> I have reduce the scope of the problem in the topic I writed. In fact this datatype contain additionnal information
> that we use for databinding validation(such as "minInclusive", ....), but those informations are not usefull for the
> problem I expose.
> I have reproduce the problem with this scope.
Not sure what you mean by "reduced the scope".
CDO can currently not deal with custom data types that have a primitive instance type. I imagine there could by a
solution by enhancing one of the two (or both) methods:
CDONotificationBuilder.createNotification(int, EStructuralFeature, Object, Object, int)
CDONotificationBuilder.createPrimitiveNotification(int, EStructuralFeature, Class<?>, Object, Object)
Would you like to investigate that with your example?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] custom data type/Class cast exception on notification [message #1622421 is a reply to message #1622252] |
Wed, 18 February 2015 08:37   |
Eike Stepper wrote on Wed, 18 February 2015 11:13Am 18.02.2015 um 12:06 schrieb David Ponzo:
> How does the server to distinguish EMF standard datatypes from custom ones ?
> It's just to understand how it works on server-side I'm using a mem-based server.
Each repository maintains a package registry and knows everything about the used models.
Hence, if the server knows everything on the used meta-model, it could retrieve easiliy if a custom datatype refers to a primitive type (from Instance Type Name) as the ones defined by the Ecore model datatypes (EDouble, EInt, ...).
Instead, I understand, you have explicit code in a cdo server that behaves in a different way based on EcorePackage.Literals.EDOUBLE etc... ?
Could you please point me where it is coded in the cdo server ?
Is it possible to enhance the default cdo server behavior to generate proper notifications based on instance type name from a datatype instead of EMF pre-defined datatypes ?
Either you modifiy the cdo server ( or offer the possibility to add this behavior in extending the CDO server ?
> By the way, what is the meaning of the server (config.xml file) property supportingEcore ?
That property is deprecated (see org.eclipse.emf.cdo.server.IRepository.Props):
Thanks for the tip.
* @since 4.0
* @deprecated As of 4.2 instances of Ecore are always supported (on demand).
@Deprecated
public static final String SUPPORTING_ECORE = "supportingEcore";
Cheers
/Eike
> David.
> Eike Stepper wrote on Wed, 18 February 2015 08:46
>> Am 18.02.2015 um 09:43 schrieb David Ponzo:
>> > It works fine with a patch on createPrimitiveNotification method.
>> Perfect. Please contribute your changes!
>> > For my general knowledge, can you tell me on whitch criteria, the cdo server decide to send String instead of
>> primitif > type ?
>> IIRC., Strings are always transfered for custom EDataTypes.
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
Re: [CDO] custom data type/Class cast exception on notification [message #1622483 is a reply to message #1622421] |
Wed, 18 February 2015 09:34  |
Am 18.02.2015 um 14:37 schrieb David Ponzo:
>> > It's just to understand how it works on server-side :) I'm using a mem-based server.
I don't think that the server is related here. Only the EMF notifications emitted by the CDO client need to be changed.
I pointed you to the two methods that need to be changed. The casts, e.g., (Number), need to be smarter.
Cheers
/Eike
FUDForum. Page generated in 0.08482 seconds
