Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Auto-increment a non-id column using annotations
[Teneo] Auto-increment a non-id column using annotations [message #1611338] |
Wed, 11 February 2015 04:52  |
Hi everybody,
I have an ecore model which I'm persisting in a PostgreSQL database using Teneo with Hibernate. In this model there is an attribute (an order number), which should be automatically incremented. I solved this using these annotations:
@GeneratedValue(strategy=GenerationType.IDENTITY)
@Column(insertable=false, updatable=false, columnDefinition="Serial not null")
This works fine, but using 'Serial' in columnDefinition will make me dependent on postgres, so I'm searching for another solution.
I can't define it as id, because I already have an id-attribute.
Thanks for any hints.
Re: [Teneo] Auto-increment a non-id column using annotations [message #1611785 is a reply to message #1611338] |
Wed, 11 February 2015 11:07   |
Hi Stefanie,
I am not a postgres expert.., but can't you try another type than serial?
gr. Martin
On 11-02-15 15:46, Stefanie Müller wrote:
> Hi everybody,
> solution.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Auto-increment a non-id column using annotations [message #1622112 is a reply to message #1622049] |
Wed, 18 February 2015 04:13   |
Hi Stefanie,
I have never used it myself but afaics you can define sequences also in JPA, so tell the DB to create a sequence:
http://en.wikibooks.org/wiki/Java_Persistence/Identity_and_Sequencing#Sequence_Strategies
Probably there are more links on the net on this providing information on it.
gr. Martin
On 18-02-15 09:16, Stefanie Müller wrote:
> Yes, I could use another type than serial, but then I have to generate the sequence for auto-incrementing on my own. I
> don't have a clue how to do that with annotations for a non-id column. Actually there is a sequence generated by using
> the type "serial".
> By the way, I only use the second annotation @Column(insertable=false, updatable=false, columnDefinition="Serial not
> null")
> the other annotation is obsolete for my purpose.
The Netherlands
Re: [Teneo] Auto-increment a non-id column using annotations [message #1622187 is a reply to message #1622175] |
Wed, 18 February 2015 05:16   |
Ha indeed, I can probably solve this (that the pkcolumnname is ignored), can you enter a bugzilla for it?
I can probably find time within 1-2 weeks to solve this.
Which version of Teneo are you on? (I prefer to solve things in the latest 2.1.0 version)
gr. Martin
On 18-02-15 11:08, Stefanie Müller wrote:
> Hi Martin,
> thanks for this hint.
> I tried to use these annotations
> @TableGenerator(name="TABLE_GEN", table="SEQUENCE_TABLE", pkColumnName="SEQ_NAME", valueColumnName="SEQ_COUNT",
> pkColumnValue="EMP_SEQ")
> @GeneratedValue(strategy=GenerationType.TABLE, generator="TABLE_GEN")
> but the sequence_table isn't generated correctly. I found a previous topic (www.eclipse.org/forums/index.php/t/154301/)
> where you said: "...that pkColumn* are not being picked up by Teneo". Is this still the behaviour of Teneo?
> Thanks in advance!
> Regards, Steffi
The Netherlands
Re: [Teneo] Auto-increment a non-id column using annotations [message #1622355 is a reply to message #1622341] |
Wed, 18 February 2015 07:37   |
Hi Stefanie,
I found this thread on the same topic:
http://stackoverflow.com/questions/277630/hibernate-jpa-sequence-non-id
It describes some workarounds, the main thing (after reading really quickly) is to generate the value yourselve in java.
The above is an old thread, maybe latest Hibernate versions provide different support, for the latest Hibernate you need
to use Teneo 2.1.0.
Hope it helps.
gr. Martin
On 18-02-15 13:26, Stefanie Müller wrote:
> Hi Martin,
> I'm afraid I forgot to test, if the sequence-table is also generated with a non-id column... The resolution is - it
> doesn't.
> Thus these annotations are unfortunately no solution and I won't enter a bugzilla :(
> Nevertheless I'm really thankful for your input :)
> Regards, Steffi
The Netherlands
Current Time: Wed Jul 30 22:17:28 EDT 2025
Powered by FUDForum. Page generated in 0.04413 seconds
