Home » Language IDEs » Java Development Tools (JDT) » can not add a breakpoint in Eclipse
can not add a breakpoint in Eclipse [message #162173] Mon, 31 May 2004 21:50 Go to next message
Originally posted by: wlbrant.pmail.ntu.edu.sg
I'm new to Eclipse. I just downloaded Eclipse 3.0M9.
I try to add one breakpoint to debug the a java program, but after I chose
"Toggle breakpoint" from the popup menu, I got an error dialog, which read:
Cannot add breakpoint
Reason:
Error logged from JDT Debug UI:
Above is the complete error msg I got.
Is there any missing steps that I need to fix first before I can use the
debug feature of Eclipse?
Re: can not add a breakpoint in Eclipse [message #162180 is a reply to message #162173] Tue, 01 June 2004 00:01 Go to previous messageGo to next message
I believe this is the bug with an interaction with the new code folding.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=62266
You can turn off code folding or select a line of code where you wish to add
the breakpoint and use the Window Run menu to add a breakpoint
(Ctrl-Shift-B)
HTH
Darins
"wlbrant" <wlbrant@pmail.ntu.edu.sg> wrote in message
news:c9gndi$b9h$1@eclipse.org...
read:
> Reason:
> Thanks
Re: can not add a breakpoint in Eclipse [message #162188 is a reply to message #162180] Tue, 01 June 2004 01:51 Go to previous message
it does work.
Thanx.
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:c9gr2v$ess$1@eclipse.org...
add
> (Ctrl-Shift-B)
> HTH
> Darins
chose
> read:
> > Reason:
> > Thanks
Previous Topic:How to use the TAB key to indent a line of code?
Next Topic:ftp ant task in M9?
Current Time: Sat Jul 19 04:11:03 EDT 2025
Powered by FUDForum. Page generated in 0.04660 seconds
