Home » Eclipse Projects » Eclipse 4 » No events received when I listen outside the class who sends
No events received when I listen outside the class who sends [message #1619227] Mon, 16 February 2015 07:27 Go to next message
Dear experts,
I am sending my event through the bus but event listeners are seemingly not waken up by it. Only those listeners within the same class/file where the event is sent, react to it.
It seems to me that only classes directly linked to the application model via classURI are connected to the event bus... I also tried also with Eclipse events like UIEvents.UILifeCycle.APP_STARTUP_COMPLETE and still only the UI handlers receives the signal.
Is this an expected behaviour, and in this case: how would I be able to include all my classes in the happy yellow Event submarine system?
For instance:
public class WhateverWherever {
	@Inject
	@Optional
	private void postAppComplete(
			@UIEventTopic(UIEvents.UILifeCycle.APP_STARTUP_COMPLETE) Event event) {
		// Start listening socket;
		System.out.println("No way to get here.");
		// do stuff
thanks for your support,
-Piero
Re: No events received when I listen outside the class who sends [message #1619588 is a reply to message #1619227] Mon, 16 February 2015 12:45 Go to previous messageGo to next message
Are your objects created via injection container? E.g. Using the ContextInjectionFactory?
The events are injected, therefore you only receive events in objects created this way.
Re: No events received when I listen outside the class who sends [message #1620618 is a reply to message #1619588] Tue, 17 February 2015 05:03 Go to previous messageGo to next message
Thank you Dirk.
Do you mean if I ContextInjectionFactory.inject() my WhateverWherever class in the example somewhere in the plugin? No, I didn't and I am sorry if I missed that somewhere in the docs.
In practice... does this mean that the scope of the events' bus is delimited by those classes in the application context?
Which means, without further programmer intervention, command or part handlers or anyway any class referred to in the application model (via classURI) ?
As Lars (thank you Lars for all the material you provide, God bless you) or one of his slaves writes in [1], the event bus is not aware of the context hierarchy (so no events' hierarchy neither) but I interpreted this as "events bus and context are completely separate things." I'd like to fully understand the logic here
[1] http://www.vogella.com/tutorials/Eclipse4EventSystem/article.html#eventsystem_summary
Meanwhile, my working workaround is now to implement a pure-OSGi "event handler" as org.osgi.service.event.EventHandler, and by registering it in the plugin activator:
public class Activator implements BundleActivator {
        public static final String MY_EVENT = "myEvent";
	public void start(BundleContext bundleContext) throws Exception {
                /*** REGISTER MY_EVENT HANDLER ***/
		String topic = MY_EVENT;
		Dictionary<String, Object> properties = new Hashtable<String, Object>();
		properties.put(EventConstants.EVENT_TOPIC, topic);
		ServiceRegistration eventRegistration = context
				.registerService(EventHandler.class.getName(),
						new WhateverWherever(),
						properties);
		eventRegistration.getReference();
public class WhateverWherever implements EventHandler {
        /*** HANDLE MY_EVENT EVENT ***/
	public void handleEvent(Event event) {
		System.out.println("Event received : https://sometimesigetangry.files.wordpress.com/2011/06/fuck_yea_in_hd_by_crusierpl_re_sharenator_is_growing-s900x773-1208112.png.");
		// do stuff
Still in this case I am not able to obtain a complete integration of my WhateverWherever class in the Eclipse event's bus, so I won't be able to register to events like APP_STARTUP_COMPLETE or other {@link org.eclipse.e4.ui.workbench.UIEvents}.
Thanks again for your patience, to all.
-Piero
Re: No events received when I listen outside the class who sends [message #1620957 is a reply to message #1620618] Tue, 17 February 2015 10:01 Go to previous message
Hello Piero,
I think what is meant by the event bus "not being aware of contexts" is that the eventbus "broadcasts" its events to all listeners, regardless of contexts.
If you want to use @UIEventTopic, you have to do so in a location where Eclipse can perform dependency injection, this means in a context function or in any Java class referred by the application model.
If you can't use DI in your use case, registering an eventhandler seems the way to go. As an alternative, you can also use a declarative service. For instance (taken from http://eclipsesource.com/blogs/2009/09/15/osgi-eventadmin/)
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0"
   name="org.eclipse.example.memoryHandler">
<implementation class="org.eclipse.example.MemoryEventHandler"/>
<service>
 <provide interface="org.osgi.service.event.EventHandler"/>
</service>
 <property name="event.topics" value="org/eclipse/equinox/events/MemoryEvent/CRITICAL" />
</scr:component>
Previous Topic:Custom window heading
Next Topic:Injecting preferences
Current Time: Wed Jul 23 22:56:47 EDT 2025
Powered by FUDForum. Page generated in 0.05361 seconds
