Home » Eclipse Projects » GEF » How do you run the GEF examples
How do you run the GEF examples [message #161984] |
Fri, 17 December 2004 12:35  |
Originally posted by: pete.telenet.demon.co.uk
I've downloaded Eclipse, and got "Hello World" working. Great.
Now I've downloaded the GEF examples, and, as instructed,
unzipped them into my "main Eclipse" directory. (I presume that this
means the subdirectory called "eclipse" of the top-level eclipse
directory
(ie. eclipse-SDK-3.0.1-win32/eclipse/)). All seems to have gone fine.
But when I do Ctrl-N, the wizard does not have an "Examples" Folder
as indicated in the instructions. I've tried a few other things, but
don't want to mess up the installation.
All I want to do is run the examples....
Can someone help?
Thanks.
The instructions say:
Download and unzip the latest 3.1 GEF Examples from the GEF Project
Downloads into your main Eclipse directory. To create a new diagram, launch
the wizard by pressing Ctrl-N. Expand the Examples folder and select Shapes
Diagram.
Re: How do you run the GEF examples [message #161994 is a reply to message #161984] |
Fri, 17 December 2004 13:06   |
Actually, the build process has changed so that the zip now includes the
eclipse directory. So, you want to unzip in eclipse folder's parent
directory. The FAQs have been updated.
"P T" <pete@telenet.demon.co.uk> wrote in message
news:cpv5cm$4p2$1@www.eclipse.org...
> directory
> Can someone help?
> Thanks.
launch
Shapes
> Diagram.
Re: How do you run the GEF examples [message #162000 is a reply to message #161994] |
Fri, 17 December 2004 13:18   |
I've tried that too, but when I do a Ctrl-N, I get the following choice:
Class
Extension Point Schema
Interface
Java Project
Plug-in Project
(+)CVS
(+)Java
(+)Plug-in Development
(+)Simple
No sign of Examples, as indicated in the instructions...
Any ideas?
Thanks.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cpv777$b17$1@www.eclipse.org...
>> Hi,
>> directory
>> Can someone help?
>> Thanks.
> launch
> Shapes
>> Diagram.
Re: How do you run the GEF examples [message #162007 is a reply to message #162000] |
Fri, 17 December 2004 13:33   |
Are the plug-ins activated in the About dialog? Any warnings/errors in the
error log? The versions of GEF and examples that you're using are the same,
right?
news:cpv7vg$dhm$1@www.eclipse.org...
choice:
> Class
> Interface
> Java Project
> Plug-in Project
> (+)CVS
> (+)Java
> (+)Simple
> Any ideas?
> Thanks.
> >> Hi,
this
> >> directory
fine.
but
> >> Can someone help?
> >> Thanks.
> > launch
> > Shapes
> >> Diagram.
Re: How do you run the GEF examples [message #162015 is a reply to message #162007] |
Fri, 17 December 2004 14:16   |
>Yes the plug-ins appear in the Help->About->PlugInDetails screen,
>they are version 3.0.1, the same as my eclipse version,
>there is no error log, and it says that the reason for this is
>because there have been no errors since installation.
>If I do a Ctrl-N, I just get the options listed below...
Not sure what's going on. Try creating a new file with the .shapes
extension or the .logic extension and see if they open up in GEF editors.
Also, just to make sure, you got both the SDK zip and the Examples zip from
the download page, right?
news:cpv8pe$g87$1@www.eclipse.org...
the
same,
> right?
> > Thanks,
> choice:
> > Class
> > Interface
> > Java Project
> > Plug-in Project
> > (+)CVS
> > (+)Java
> > (+)Simple
> > Any ideas?
> > Thanks.
the
> > >> Hi,
> this
> > >> directory
> fine.
Folder
> but
> > >> Can someone help?
> > >> Thanks.
> > > launch
> > > Shapes
> > >> Diagram.
Re: How do you run the GEF examples [message #162023 is a reply to message #162015] |
Fri, 17 December 2004 14:18   |
Actually, the shapes example was not in 3.0.1, so just try the logic
extension.
news:cpvbb8$obc$1@www.eclipse.org...
from
> the
> same,
> > right?
> > > Thanks,
> > choice:
> > > Class
> > > Interface
> > > Java Project
> > > Plug-in Project
> > > (+)CVS
> > > (+)Java
> > > (+)Simple
> > > Any ideas?
> > > Thanks.
> the
> > > >> Hi,
> > this
eclipse
> > > >> directory
> > fine.
> Folder
things,
> > but
> > > >> Can someone help?
> > > >> Thanks.
diagram,
> > > > launch
select
> > > > Shapes
> > > >> Diagram.
Re: How do you run the GEF examples [message #162057 is a reply to message #162000] |
Sat, 18 December 2004 02:11   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
P T wrote:
> Class
> Interface
> Java Project
> Plug-in Project
> (+)CVS
> (+)Java
> (+)Simple
> Any ideas?
> Thanks.
>>>Hi,
>>>directory
>>> Can someone help?
>>>Thanks.
>>launch
>>Shapes
>>>Diagram.
I thought the new method was to create a plugin project, then use the
import external plugin or some such to import the example jars into your
plugin project.
of course that dont allow manipulation of the source.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: How do you run the GEF examples [message #162237 is a reply to message #162023] |
Mon, 20 December 2004 12:12  |
Hi again,
I have re-installed the whole thing and now it all works fine.
I had installed the GEF SDK, but in the wrong subdirectory,
as a result of accepting Windows default unzip target folder suggestion.
(I normally use Linux, which doesn't make such suggestions)
Thanks Pratik for all your help,
P T
Pratik Shah wrote:
> No, I meant the GEF SDK zip. You need that to be able to run the GEF
> examples.
PT wrote:
> > Yes both the eclipseSDK and the GEFExamples are from
> > the eclipse.org download site, both version 3.0.1
Current Time: Wed Jul 30 08:57:15 EDT 2025
Powered by FUDForum. Page generated in 1.13600 seconds
