Home » Eclipse Projects » GEF » Changing getContentsPane()
Changing getContentsPane() [message #161940] Fri, 17 December 2004 11:34 Go to next message
Given all of the un-understanding about addChildVisual(),
setLayoutConstraint(), nested figures in a single EditPart, etc, etc, etc
what if AbstractGraphicalEditPart.getContentPane() was changed to be
getContentPane(EditPart child)? In the default case there would be no
difference (it would effectively ignore the child EditPart). For those that
want to use nested figures the new getContentPane() would return the figure
specific to that child EditPart allowing addChildVisual(),
setLayoutConstraint(), etc to function correctly and without modification.
Thank you.
Rob Grzywinski
Re: Changing getContentsPane() [message #161960 is a reply to message #161940] Fri, 17 December 2004 12:14 Go to previous messageGo to next message
The indexes would be off if there were more than one contents pane. I would
suggest overriding addChildVisual(child, index), and take the index and do a
contents pane lookup, and index correction, all in one place.
getContentsPane would just be unused.
"Rob Grzywinski" <rgrzywinski@realityinteractive.com> wrote in message
news:cpv1r6$o1f$1@www.eclipse.org...
that
figure
> Thank you.
> Rob Grzywinski
Re: Changing getContentsPane() [message #161975 is a reply to message #161960] Fri, 17 December 2004 12:20 Go to previous messageGo to next message
> would
> a
But then you get nipped with the setLayoutConstraint() "Figure is not a
child" and you have to do the same goop there too (minus the index stuff).
So I ended up writing a getContentPane(EditChild) to use between the two of
them and voila! you have my original post.
I will admit that I'm less than pleased about the whole index problem in
addChildVisual(). Why can't they be sparse?
Rob Grzywinski
Re: Changing getContentsPane() [message #162031 is a reply to message #161975] Fri, 17 December 2004 14:34 Go to previous messageGo to next message
We can change setLayoutConstraint to get the figure's parent, which should
be the contents pane in general.
news:cpv4hf$1rr$1@www.eclipse.org...
> > would
do
> > a
of
> Rob Grzywinski
Re: Changing getContentsPane() [message #162036 is a reply to message #162031] Fri, 17 December 2004 15:57 Go to previous messageGo to next message
public void setLayoutConstraint(EditPart child, IFigure childFigure, Object
constraint) {
childFigure.getParent().getLayoutManager().setConstraint(chi ldFigure,
constraint);
That appears to be a general solution to that particular problem, I agree.
Rob Grzywinski
Re: Changing getContentsPane() [message #163073 is a reply to message #162036] Thu, 30 December 2004 17:18 Go to previous message
> Object constraint) {
> constraint);
It ends up that this is not entirely correct as there is no revalidate()
called on the parent figure which would result in the re-bounding of the
child figure. A more correct solution would be:
childFigure.getParent().setConstraint(childFigure, constraint);
Rob Grzywinski
Previous Topic:Running GEF Shapes Example in Run-Time Workbench: java.lang.ExceptionInInitializerError
Next Topic:how to disable posibility to resize elements?
Current Time: Wed Jul 30 15:30:22 EDT 2025
Powered by FUDForum. Page generated in 0.03857 seconds
