Home » Language IDEs » C / C++ IDE (CDT) » cannot debug my application with CDT
cannot debug my application with CDT [message #161828] Sun, 15 January 2006 10:08 Go to next message
Originally posted by: javacard.hotmail.com
Hi all,
After istalled Eclipse 3.1.1 SDK,CDT 3.0.1 as well as Mingw 5.0.0,I could
execute 'run' the application.But when I operate the 'debug' ,the 'cygwin
GDB debugger' is suspended,and the console window prompts
:"mi_cmd_stack_list_frames: No stack."
really don't know how to solve it.
XS
Re: cannot debug my application with CDT [message #161840 is a reply to message #161828] Sun, 15 January 2006 12:53 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
This message is not an error, ignore it. Can you step, resume, etc?
"Xu Song" <javacard@hotmail.com> wrote in message
news:dqdohp$bqn$1@utils.eclipse.org...
> Hi all,
> XS
Re: cannot debug my application with CDT [message #161847 is a reply to message #161840] Sun, 15 January 2006 22:25 Go to previous messageGo to next message
No,step and resume don't work either.
I create a managed make C project,setup binary parser with 'PE Windows
Parser'.Then try to debug the sample application,the 'cygwin GDB Debugger'
is suspended:Singnal 'SIGTRAP' received.
When I click 'step over', console window shows:Program received signal
SIGTRAP,Single stepping until exit from function _libmsvcrt_a_iname, which
has no line number information.
Afterwards I open DOS command prompts,and try the gdb with eclipse.The gdb
also has the similar warning message:Program received signal SIGTRAP,
Trace/breakpoint trap.
This issue looks like MinGW related.But I've tried with MinGW 3.1.0/5.0.0 as
well cygwin,no one works. What's recommended compiler for eclipse CDT?
XS
"Mikhail Khodjaiants" <mikhailkhod@rogers.com>
??????:dqe2i1$pel$1@utils.eclipse.org...
>> Hi all,
>> XS
Re: cannot debug my application with CDT [message #161895 is a reply to message #161847] Mon, 16 January 2006 10:49 Go to previous messageGo to next message
There is no such a thing as recomended compiler for CDT. CDT is just a front
end for your tool chain.
As I can tell there is something wrong with your executable or environment.
news:dqf3ng$44j$1@utils.eclipse.org...
> as well cygwin,no one works. What's recommended compiler for eclipse CDT?
> XS
>>> Hi all,
>>> could
>>> 'cygwin
>>> XS
Re: cannot debug my application with CDT [message #161949 is a reply to message #161895] Mon, 16 January 2006 20:24 Go to previous message
you're right.I've downgraded MinGW from 5.0 to 3.1.0,then installed the
previous Eclipse 3.1.0,everything just worked fine.
I don't have time to test all version's interoperability,but 'to use the
stable one is important than the new one'.
One more point is:I used to install Visual C 6.0 build tool in the same
machine,but the MinGW/CDT environment doesn't work until I uninstall the
VC build tool.
XS
Previous Topic:newbie stuck getting started - how to tell cdt where g++ is?
Next Topic:Stack Selection is MT safe?
Current Time: Sat Nov 08 20:00:27 EST 2025
Powered by FUDForum. Page generated in 0.05188 seconds
