Home » Modeling » GMF (Graphical Modeling Framework) » Modify WrapLabel text
Modify WrapLabel text [message #161676] Tue, 20 November 2007 09:07 Go to next message
Originally posted by: snej_NO-SPAM_.esuark.de
Hi There,
i have several cardinality labels which shows int values
(cardinalities). So also "-1" for unlimited could appear. I want the
"-1" shown as "*" like in uml diagrams.
Could i modify any code for that? If so, where do i have to start?
regards
jens
Re: Modify WrapLabel text [message #161750 is a reply to message #161676] Wed, 21 November 2007 04:30 Go to previous messageGo to next message
Originally posted by: jan.herriger.gmx.de
Hi Jens,
this can be seen in the sample ecore editor.
In the mapping model, set ViewPattern to '{0}..{1,choice,-1#*|-1<{1}}'.
Or change code in xxxParserProvider accordingly.
cheers
Jan
Jens Krause schrieb:
> Hi There,
> regards
> jens
Re: Modify WrapLabel text [message #162224 is a reply to message #161750] Fri, 23 November 2007 04:15 Go to previous messageGo to next message
First of all, thanks for your answer.
Is there any documentation about these pattern syntax and possible commands?
jens
Re: Modify WrapLabel text [message #162261 is a reply to message #162224] Fri, 23 November 2007 06:02 Go to previous message
There is some documentation in
http://java.sun.com/javase/6/docs/api/java/text/MessageForma t.html
> jens
Previous Topic:Integrate EMF into RCP GMF application
Next Topic:one from two
Current Time: Fri Jul 25 23:29:43 EDT 2025
Powered by FUDForum. Page generated in 0.24165 seconds
