J2EE Module Dependencies and Server-Side Equinox OSGi [message #161713] |
Thu, 23 February 2006 00:04  |
Originally posted by: jfallows.txesystems.com
Folks,
As you may already know, there is a functional prototype in the
equinox-incubator to enable server-side OSGi deployed as a traditional
web application.
The directory structure layout within such an OSGi "bridge" web
application is as follows:
[webapp-root]
WEB-INF/
lib/ (equinox-bridge JAR goes here)
platform/
configuration/
config.ini
plugins/ (embedded OSGi plugins go here)
So, here is a use case for deploying both plugin and module dependency
JARs to a directory other than WEB-INF/lib.
There is currently no UI in Eclipse yet for defining the set of OSGi
plugins to publish to WEB-INF/platform/plugins.
Digging a little more, I discovered the following project settings saved
in .settings/.component
<project-modules id="moduleCoreId">
<wb-module deploy-name="osgi-bridge-webapp">
<wb-resource deploy-path="/WEB-INF/classes" source-path="/src"/>
<wb-resource deploy-path="/" source-path="/WebContent"/>
<dependent-module deploy-path="/WEB-INF/lib"
handle=" module:/resource/org.eclipse.equinox.servlet.bridge/org.ecli pse.equinox.servlet.bridge ">
<dependency-type>uses</dependency-type>
</dependent-module>
<property name="java-output-path" value="/build/classes/"/>
<property name="context-root" value="osgi-bridge-webapp"/>
</wb-module>
</project-modules>
Looking at this syntax, it seemed as though the target directory can be
controlled by deploy-path="/WEB-INF/lib". So, it would be very
convenient if all the plugins needed could be listed here, and deployed
to WEB-INF/platform/plugins instead of WEB-INF/lib.
However, manually changing this value (since there is no UI yet) to
"WEB-INF/platform/plugins" does not get the desired effect, only JARs
targeted for WEB-INF/lib are deployed and the others are ignored.
Can anyone comment on the expected behavior of deployment when this
deploy-path attribute is set to something other than "WEB-INF/lib"?
Many thanks in advance.
Kind Regards,
John Fallows.
Author: Pro JSF and Ajax: Building Rich Internet Components
http://apress.com/book/bookDisplay.html?bID=10044
Re: J2EE Module Dependencies and Server-Side Equinox OSGi [message #170042 is a reply to message #161713] |
Wed, 24 May 2006 12:27  |
Originally posted by: thisisnot.mymail.com
John R. Fallows wrote:
> Folks,
> web application.
> [webapp-root]
> WEB-INF/
> platform/
> configuration/
> config.ini
> </dependent-module>
> </wb-module>
> </project-modules>
> Kind Regards,
> John Fallows.
Excellent question, what's the plan for OSGi/Equinox on the wtp?
Srgjan
FUDForum. Page generated in 0.27673 seconds
