Home » Eclipse Projects » e(fx)clipse » How to create an editor with syntax highlighting for Java (tutorial)
How to create an editor with syntax highlighting for Java (tutorial) [message #1616219] Sat, 14 February 2015 07:09 Go to next message
Following this torial, I'm stuck even before starting
i have doing this steps
Download Java8u40 (at the time of this writing you need to use an EA build)
Download e(fx)clipse all-in-one downloads
Clone the following git-repositories:
http://git.eclipse.org/c/platform/eclipse.platform.text.git/
http://git.eclipse.org/c/efxclipse/org.eclipse.efxclipse.git/
Now for the rest, sincerely i do not know where to start.
To implement the tutorial should we start with a simple JavaFX Application or an E4 JavaFX application, I am confused, I never writing editor for eclipse it's my first steps
[Updated on: Sat, 14 February 2015 07:10] by Moderator
Re: How to create an editor with syntax highlighting for Java (tutorial) [message #1616246 is a reply to message #1616219] Sat, 14 February 2015 07:31 Go to previous messageGo to next message
No you don't create anything just clone the git repos and import the mentionned projects
Re: How to create an editor with syntax highlighting for Java (tutorial) [message #1616303 is a reply to message #1616246] Sat, 14 February 2015 08:26 Go to previous messageGo to next message
it works, I misunderstood the first time , I thought I had to create my own project, and use dependencies with imported project
there a little problem with the number key on the top of the keyboard, certain key combination does not work like Alt+2 to get @
[Updated on: Sat, 14 February 2015 14:00] by Moderator
Re: How to create an editor with syntax highlighting for Java (tutorial) [message #1616309 is a reply to message #1616303] Sat, 14 February 2015 08:32 Go to previous messageGo to next message
File bugs for things that don't work so that we can fix them
Re: How to create an editor with syntax highlighting for Java (tutorial) [message #1616351 is a reply to message #1616309] Sat, 14 February 2015 09:14 Go to previous messageGo to next message
there's a bug trackers ? or i will use e(fx)clipse to report a bug
for me i have a french Layout Keyboard,
for example to get opening brace i must press Alt Gr + 4 (doesn't work), also all the key combination fails.
after trying, it's the same things with english keyboard layout
for example to get capital letter :
Caps Lock + (letter) => work
Shift + (letter) don't work
Re: How to create an editor with syntax highlighting for Java (tutorial) [message #1618935 is a reply to message #1616351] Mon, 16 February 2015 03:16 Go to previous messageGo to next message
Of course there is a bugtracker. Anyways I went a head and reworked key
event handling while communting to work and hopefully fixed the problem
with https://bugs.eclipse.org/bugs/show_bug.cgi?id=459973.
Please pull the efxclipse git repo and try out if things are now working
for you. I guess the current code only worked on OS-X and I hope this is
now working appropriately for cross platform apps.
Tom
> for me i have a french Layout Keyboard, for example to get opening brace
Re: How to create an editor with syntax highlighting for Java (tutorial) [message #1621317 is a reply to message #1618935] Tue, 17 February 2015 15:43 Go to previous messageGo to next message
You might be interested in a project I made public just a few minutes
ago
http://tomsondev.bestsolution.at/2015/02/17/compensator-a-code-editor-and-a-code-dev-environment-written-in-javafx/
Tom
On 16.02.15 09:16, Tom Schindl wrote:
> Tom
Re: How to create an editor with syntax highlighting for Java (tutorial) [message #1623118 is a reply to message #1618935] Wed, 18 February 2015 18:54 Go to previous messageGo to next message
Thomas Schindl wrote on Mon, 16 February 2015 03:16
Tom
thanks Tom, I'll test this and if there are bugs I'll report them on the bugtraker
Thomas Schindl wrote on Tue, 17 February 2015 15:43
ago
Tom
That seems very interesting, I'll watch it tomorrow
Re: How to create an editor with syntax highlighting for Java (tutorial) [message #1623659 is a reply to message #1618935] Thu, 19 February 2015 03:32 Go to previous message
Tom
i confirm, i have tested and it's work fine now on windows, i will also try in Linux, just a time to install a virtualBox machine
Previous Topic:Cannot complete the install because of a conflicting dependency
Next Topic:JavaFX application deployment
Current Time: Tue Sep 16 22:30:48 EDT 2025
Powered by FUDForum. Page generated in 0.04655 seconds
