Home » Newcomers » Newcomers » Share Source between 2 web projects
Share Source between 2 web projects [message #161479] Tue, 18 July 2006 16:12 Go to next message
Wayne -
First of all, thanks for your quick response.
We are trying to move from JBuilder to Eclipse and I tried setting up
everything as you suggested but I am running into one problem.
I did add the Java project as a "J2EE Module Dependency" in the web
project but my web project can't find all the classes defined in the Java
Project.
Please let me know if I am missing something or am I doing something wrong.
Thanks.
Rahul
-----Original Message-----
From: Wayne Beaton [mailto:wayne.beaton@_NOSPAM_eclipse.org]
Sent: Tuesday, July 18, 2006 10:06 AM
To: Rahul Kumar
Subject: Re: Share Source between 2 web projects
Rahul Kumar wrote:
> Hi -
> How do I share the source code between two different web projects? I
> am able to share source between a web project and multiple Java projects.
> Please let me know.
> Thanks.
> Rahul
Put the common code in a Java project and have both web projects reference
it as a "J2EE Module Dependency" (in the project properties).
This has the same effect as packaging the Java project as a JAR and
putting into the WEB-INF/lib directory (which is exactly what will happen
when you export the Web Project).
Wayne
Re: Share Source between 2 web projects [message #161488 is a reply to message #161479] Tue, 18 July 2006 16:19 Go to previous message
> Java Project.
Can it find some of the classes? If so, that's a little weird... Are the
classes it can't find in the default package? (I'm not sure if that
should be a problem)
Wayne
Previous Topic:Incorrect Tool Tip in Ant's build.xml
Next Topic:Share Source between 2 web projects
Current Time: Tue Jul 22 01:14:36 EDT 2025
Powered by FUDForum. Page generated in 0.08294 seconds
