Home » Eclipse Projects » GEF » Problem with picture using plugin
Problem with picture using plugin [message #161284] Sat, 11 December 2004 00:09 Go to next message
Originally posted by: pengfai81.mail.yahoo.com
hello, i'm beginner of java eclipse tools. Currentl i am using in this
tool.I have a problem of inserting pictures using this function as below:
InputStream in = getClass().getResourceAsStream("map.gif");
Label nodeLabel1 = new Label("Node4", new
Image(getViewSite().getShell().getDisplay(), in));
final NodeFigure nodeFigure1 = new NodeFigure(nodeLabel1);
panel.add(nodeFigure1, BorderLayout.CENTER);
This is the function that I found but seem like not working. Do you have
other suggestion in term to insert pictures? Thanks...
Re: Problem with picture using plugin [message #161364 is a reply to message #161284] Mon, 13 December 2004 11:08 Go to previous messageGo to next message
Are you adding the label to nodeFigure1 somewhere? What is NodeFigure's
layout?
"Michael" <pengfai81@mail.yahoo.com> wrote in message
news:cpdve2$ivf$1@www.eclipse.org...
Re: Problem with picture using plugin [message #161496 is a reply to message #161364] Mon, 13 December 2004 23:12 Go to previous messageGo to next message
> layout?
Here is the NodeFigure's code ...
public class NodeFigure extends Figure {
public NodeFigure(Label name) {
ToolbarLayout layout = new ToolbarLayout();
layout.setMinorAlignment(ToolbarLayout.ALIGN_TOPLEFT);
layout.setStretchMinorAxis(false);
layout.setSpacing(2);
setLayoutManager(layout);
add(name);
thanks in advance ...
Re: Problem with picture using plugin [message #161502 is a reply to message #161496] Tue, 14 December 2004 12:05 Go to previous messageGo to next message
Try setting some text on the label (or maybe a LineBorder) and see if it's
visible. Maybe the problem is with loading the image.
"Jack" <pengfai81@mail.yahoo.com> wrote in message
news:cplp7a$qo9$1@www.eclipse.org...
> > layout?
below:
have
> add(name);
Re: Problem with picture using plugin [message #161534 is a reply to message #161502] Wed, 15 December 2004 02:33 Go to previous messageGo to next message
>>I tried it before ...And the text label is visible. But,the problems occured
when loading the picture. Any suggestion instead of the code i have written
before?
Re: Problem with picture using plugin [message #161698 is a reply to message #161534] Wed, 15 December 2004 16:59 Go to previous messageGo to next message
I'm assuming that the image is not blank or transparent and that you're
properly loading it (you might want to double-check that by using an image
that already exists elsewhere in the workbench).
What do you see? Do you see space allocated for the Image? Can you please
attach a screenshot (with a red LineBorder around the label)?
Keep in mind that you have a ToolbarLayout located centrally inside a
BorderLayout. So, if the ToolbarLayout doesn't get enough height, part of
it will be hidden. Make the panel larger to see if it reveals anything.
What layout does it have?
news:cpopc9$khn$1@www.eclipse.org...
it's
occured
written
> before?
Re: Problem with picture using plugin [message #162535 is a reply to message #161698] Wed, 22 December 2004 03:18 Go to previous messageGo to next message
I am not clear abt why my application window can display the .gif picture
but not to plugin project.Is that different mechanism to implement it?
The node text alone is visible but if i include with image together, the
error "An error has occurred when creating this view" came out when
running the pugin project.
plugin code:
I get stucked here.Or i calling the wrong image method..
Thanks...
Re: Problem with picture using plugin [message #162704 is a reply to message #162535] Thu, 23 December 2004 14:21 Go to previous messageGo to next message
Probably. Look at what exception is logged in the error log. That will
tell you what the problem is.
Try creating your Image like this and see if that works:
Image img = new Image(null, ImageDescriptor.createFromFile(getClass(),
"map.gif").getImageData());
This is assuming that the file map.gif is in the same package as the class
which invokes the above code.
news:cqbajn$n29$1@www.eclipse.org...
> plugin code:
> Thanks...
Re: Problem with picture using plugin [message #162755 is a reply to message #162704] Mon, 27 December 2004 00:27 Go to previous message
thanks ,it solved the problem ...
Previous Topic:When getCreateCommand() will be called?
Next Topic:Selection in outline view and editor
Current Time: Wed Jul 30 17:12:17 EDT 2025
Powered by FUDForum. Page generated in 0.04058 seconds
