Home » Eclipse Projects » e(fx)clipse » org.eclipse.fx.ui.dialogs not found
org.eclipse.fx.ui.dialogs not found [message #1613589] Thu, 12 February 2015 14:22 Go to next message
hello all
i have installed e (fx) clipse on Luna a plugin, to take a look to Tom Schindl project fx-ide , found ont the followin github repository
https://github.com/tomsontom/fx-ide
but i have some missing packge
org.eclipse.fx.ui.dialogs.Dialog;
what there is a wrong with my e(fx)clipse ?
i have installed e(ffx)clipse from this update sie
http://download.eclipse.org/efxclipse/updates-released/1.2.0/site
[Updated on: Thu, 12 February 2015 14:44] by Moderator
Re: org.eclipse.fx.ui not found [message #1613595 is a reply to message #1613589] Thu, 12 February 2015 14:29 Go to previous messageGo to next message
This repository has unmaintained code which only worked with previous
versions of e(fx)clipse.
This very error although might be because you have not defined a target
platform in your workspace.
I guess you are interested in the styled text stuff to use of syntax
hightlighting?
Tom
On 12.02.15 20:23, AIT YAHIA Idir wrote:
> hello all
> je ai installé e (fx) clipse sur Luna comme plugin, et je veux regarder
> vers projet fx-ide de Tom Schindl, found ont tghe following ithub
> repository
> but i have some missing packge org.eclipse.fx.ui.dialogs.Dialog;
Re: org.eclipse.fx.ui not found [message #1613629 is a reply to message #1613595] Thu, 12 February 2015 14:57 Go to previous messageGo to next message
effectively I am very interested in syntax
highlighting,
when I have installed e (fx) eclipse I dont have a choice of platform, as we can see in this tutorial http://www.eclipse.org/efxclipse/install.html
i will try with a Preconfigured distributions
Re: org.eclipse.fx.ui not found [message #1613646 is a reply to message #1613629] Thu, 12 February 2015 15:12 Go to previous messageGo to next message
This has nothing to do with your installation!
The project you are trying to look at compile against a so called target
platform and you have not set this platform!
See https://wiki.eclipse.org/Efxclipse/Tutorials/Tutorial4 how you
define a target platform for your workspace.
Anyways fx-ide used orion & webview for syntax hightlighting, since then
we have improved the styled-text control which can now be used for the
highlighting when used together with the eclipse.text framework.
Tom
> highlighting,
Re: org.eclipse.fx.ui not found [message #1614523 is a reply to message #1613646] Fri, 13 February 2015 04:54 Go to previous messageGo to next message
thanks for taking the time to reply to my request
is too complicated to run the project with the new platform, I have resolved the problem related to org.eclipse.fx.ui.dialogs and I had others missing dependencies plugins like (org.eclipse.jdt.* , org.eclipse.debug.* and org.eclipse.fx.ide.jdt) .
I have added them to the Build Path of at.bestsolution.javafx.ide.jdt bundle without success, to run the project.
Thomas Schindl wrote on Thu, 12 February 2015 15:12
since then
where can i take a look to the new improved styled-text control,
Re: org.eclipse.fx.ui not found [message #1614852 is a reply to message #1614523] Fri, 13 February 2015 09:41 Go to previous messageGo to next message
I'll write up a blog post explaining how one can write a syntax
highlighting editor.
Tom
>> since then
Re: org.eclipse.fx.ui not found [message #1614913 is a reply to message #1614852] Fri, 13 February 2015 10:26 Go to previous messageGo to next message
I hope this is easy enough to get you started. If you want use another
IDE than Eclipse you need to some more extra work but this is nothing I
can do for you as part of my OSS time.
http://tomsondev.bestsolution.at/2015/02/13/how-to-create-an-editor-with-syntax-highlighting-for-java/
I fully understand that that consuming all this is not as easy as adding
a few maven dependencies but our main target are OSGi applications who
retrieve their stuff from a p2/obr-r5 repository as much as I'd love to
make this consumable easier outside the OSGi world we are not having the
resources to do so.
Tom
> Tom
>>> since then
Re: org.eclipse.fx.ui not found [message #1616147 is a reply to message #1614913] Sat, 14 February 2015 05:57 Go to previous message
I am trying to make the tutorial, i am ashamed but I'm stuck even before starting , I'll leave comments on the tutoriali am trying
Previous Topic:Build e(fx)clipse Project not executing
Next Topic:Cannot complete the install because of a conflicting dependency
Current Time: Sun Jun 15 04:56:14 EDT 2025
Powered by FUDForum. Page generated in 0.06016 seconds
