Delete EditPart/Figure [message #161102] |
Thu, 09 December 2004 09:50  |
Originally posted by: seb01016.fh-hagenberg.at
Hi!
I have got following question: Which steps are needed to make it possible
to delete an EditPart by pressing the DEL button?
I have an Editor, that extends GraphicalEditorWithPalette. I implemented
following method:
protected KeyHandler getSharedKeyHandler(){
if (sharedKeyHandler == null){
sharedKeyHandler = new KeyHandler();
// configure common keys for all viewers
sharedKeyHandler.put(KeyStroke.getPressed(SWT.DEL, 127, 0),
getActionRegistry().getAction(ActionFactory.DELETE.getId())) ;
return sharedKeyHandler;
Afterwards I added following statement in the configureGraphicalViewer()
Method
viewer.setKeyHandler(this.getSharedKeyHandler());
Next I have my own ComponentEditPolicy where I implemented the protected
Command createDeleteCommand(GroupRequest deleteRequest) method.
But if I press the del button nothing happens. Could somebody please tell
me, what i have forgotten or what I did wrong!
thx in advance
Hannes
Re: Delete EditPart/Figure [message #161215 is a reply to message #161134] |
Fri, 10 December 2004 04:53   |
You are right, I am using Eclipse 3.0 but I have a sample application
where the "Delete Process" works fine, but I can not find a big difference
to my project.
I tried to implement the keyPressed method of my key handler. Within this
method I can catch the DEL event. Therefore I thought of deleting the
EditPart manually, but I dont know how? Is this a possibility to do this???
viewer.setKeyHandler(new GraphicalViewerKeyHandler(viewer){
public boolean keyPressed(KeyEvent ev){
if(ev.getKeyCode()==SWT.DEL){
System.out.println("del event occured");
//how can i delete edit part here???
return true;
Furthermore I tried to add the delete Action to my Context menue. But this
does not work too, although undo and redo actions work fine.
public void buildContextMenu(IMenuManager menuManager){
GEFActionConstants.addStandardActionGroups(menuManager);
appendActionToUndoGroup(menuManager, ActionFactory.UNDO.getId());
appendActionToUndoGroup(menuManager, ActionFactory.REDO.getId());
appendActionToEditGroup(menuManager, ActionFactory.DELETE.getId());
I'm a little bit confused now and I don't know how can a implement the
Delete stuff.
thanks Hannes
Randy Hudson wrote:
> It sounds like the workbench's global delete action is stealing this
> keybinding, causing the Canvas to not receive the keypressed event. This is
> new behavior in 3.0 I believe.
> "Schoenboeck" <seb01016@fh-hagenberg.at> wrote in message
> news:cp9oob$d07$1@www.eclipse.org...
>> Hi!
>> following method:
>> Method
>> thx in advance
>> Hannes
Re: Delete EditPart/Figure [message #161339 is a reply to message #161215] |
Mon, 13 December 2004 10:08  |
I solved the problem. I have forgotten to implement the selection
listener. Now everything works fine.
Thx
Hannes
> to my project.
> return true;
> Delete stuff.
> thanks Hannes
>>> Hi!
>>> following method:
>>> Method
>>> thx in advance
>>> Hannes
FUDForum. Page generated in 0.08247 seconds
