Home » Modeling » ATL » ATL java Launch not working
ATL java Launch not working [message #1613386] Thu, 12 February 2015 11:17
I have an ATL transformation that works flawlessly when I use the normal way to do it, using the atl plugin.
But when I try to java launch, it cannot find the classes of a model (org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'operationalTemplateGroup' is not found or is abstract)
Exemple: I have a "operationalTemplateGroup" class on my model, but the metamodel describes it as :
<eClassifiers xsi:type="ecore:EClass" name="OPERATIONALTEMPLATEGROUP">
    <eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
      <details key="name" value="OPERATIONALTEMPLATEGROUP"/>
      <details key="kind" value="elementOnly"/>
    </eAnnotations>
See, OPERATIONALTEMPLATEGROUP and not operationalTemplateGroup, why the plugin can parse it but the java launcher dont? I have this problem with only 1 model, the others are working fine, and if I change it to operationalTemplateGroup it will work, until the next class that has the same problem, ( About 6000 lines of code ). Method:
ublic static void main(String[] args) {
    try {
        System.out.println("Running...");
         * Paths
        String inModelPath = "models/architectures/AToMS.acmehealth";
        String inModelPath2 = "models/openehr/TemplatesAToMS.openehr2008v4";
        String outModelPath = "models/richubi/TemplatesAToMS22.rich_interface_model";
        String archMMPath = "metamodels/architectures/ACMEHealthv2.ecore";
        String openEHRMMPath = "metamodels/openehr/openehr2008v4.ecore";
        String richUbiMMPath = "metamodels/richubi/rich_interface_components.ecore";
        System.out.println("inModelPath: "   inModelPath);
        System.out.println("inModelPath2: "   inModelPath2);
        System.out.println("outModelPath: "   outModelPath);
        System.out.println("archMMPath: "   archMMPath);
        System.out.println("openEHRMMPath: "   openEHRMMPath);
        System.out.println("richUbiMMPath: "   richUbiMMPath);
         * Initializations
        ILauncher transformationLauncher = new EMFVMLauncher();
        ModelFactory modelFactory = new EMFModelFactory();
        IInjector injector = new EMFInjector();
        IExtractor extractor = new EMFExtractor();
         * Load metamodels
        IReferenceModel archMetamodel = modelFactory.newReferenceModel();
        injector.inject(archMetamodel, archMMPath);
        IReferenceModel openEHRMetamodel = modelFactory.newReferenceModel();
        injector.inject(openEHRMetamodel, openEHRMMPath);
        IReferenceModel richUbiMetamodel = modelFactory.newReferenceModel();
        injector.inject(richUbiMetamodel, richUbiMMPath);
        System.out.println("Metamodels loaded.");
         * Load models and run transformation
        IModel inModel2 = modelFactory.newModel(openEHRMetamodel);
        injector.inject(inModel2, inModelPath2); // ERROR HERE!!!!
        IModel inModel = modelFactory.newModel(archMetamodel);
        injector.inject(inModel, inModelPath);
        IModel outModel = modelFactory.newModel(richUbiMetamodel);
        System.out.println("IN, OUT models loaded.");
        System.out.print("Running ATL trasformation...");
        transformationLauncher.initialize(new HashMap<String, Object>());
        transformationLauncher.addLibrary("LibHelpers",
                new FileInputStream("transformations/LibHelpers.asm"));
        transformationLauncher.addInModel(inModel, "archMM", "openEHRMM");
        transformationLauncher.addInModel(inModel2, null, "openEHRMM");
        transformationLauncher.addOutModel(outModel, "archM", "openEHRM");
                .launch(ILauncher.RUN_MODE,
                        new NullProgressMonitor(),
                        new HashMap<String, Object>(),
                                "/home/operador/workspace/Transformation/transformations/OpenEHRTemplates2RichUbi.asm"));
        System.out.println("Done.");
        System.out.print("Extracting OUT model...");
        extractor.extract(outModel, outModelPath);
         * Unload all models and metamodels (EMF-specific)
        EMFModelFactory emfModelFactory = (EMFModelFactory) modelFactory;
        emfModelFactory.unload((EMFModel) inModel);
        emfModelFactory.unload((EMFModel) outModel);
        emfModelFactory.unload((EMFReferenceModel) archMetamodel);
        emfModelFactory.unload((EMFReferenceModel) openEHRMetamodel);
    } catch (ATLCoreException e) {
        e.printStackTrace();
    } catch (FileNotFoundException e) {
Previous Topic:Invert String or Sequence
Next Topic:ATL Run Configuration
Current Time: Sun Jul 20 21:10:35 EDT 2025
Powered by FUDForum. Page generated in 0.04384 seconds
