Home » Modeling » GMF (Graphical Modeling Framework) » Custom LayoutProviders
Custom LayoutProviders [message #160998] Fri, 16 November 2007 12:13 Go to next message
Originally posted by: jdente.21technologies.com
I had a hard time getting the
org.eclipse.gmf.runtime.diagram.ui.layoutProviders extension to work. I
looked at the example SquareLayout in the plugin
org.eclipse.gmf.examples.runtime.diagram.layout. I could not get this
custom layout to work. After stepping through the code with the debugger, I
realized that the provides(IOperation operation) method on SquareLayout is
always returning false because it can only find the DEFAULT layout:
IAdaptable layoutHint = ((ILayoutNodeOperation)operation).getLayoutHint();
String layoutType = (String)layoutHint.getAdapter(String.class);
The only layoutType that seems to be registered is the default layout, and
so layoutType always equals DEFAULT. If I understand this correctly, it
seems that the layoutProviders extension is the extension point for
registering new layouts. Yet, this extension does not seem to do anything,
since even with the example plugin, only the default layout ever gets
registered.
Does anybody have any insight?
Joe
Re: Custom LayoutProviders [message #161108 is a reply to message #160998] Sun, 18 November 2007 13:09 Go to previous messageGo to next message
Originally posted by: martin.tauber.t-online.de
Joe,
could you provide some more information on what you are trying to
achieve here. I'm curious, because I have some figures in my diagram,
which need there own layout Manager, but I would have just written an
layout manager and changed the gmfgraph model to use the custom layout
for the figure ....
Joe Dente wrote:
> registered.
> Joe
Re: Custom LayoutProviders [message #161252 is a reply to message #160998] Mon, 19 November 2007 07:07 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Port diagram (that is a part of TaiPan sample) has dedicated layout
manager - you may have a look there.
Joe Dente wrote:
> registered.
> Joe
Re: Custom LayoutProviders [message #161321 is a reply to message #160998] Mon, 19 November 2007 09:31 Go to previous messageGo to next message
Joe,
It is explained here:
http://help.eclipse.org/help33/topic/org.eclipse.gmf.doc/exa mples-guide/diagram/layoutServiceExample.html
The Square Layout is used when the layout type is SQUARE_LAYOUT which
happens when you invoke the "Layout Diagram as Square" menu item under
the Sample menu. If you wanted to invoke your layout during an arrange
all or arrange selected then you would contribute your layout provider
when the layout type is DEFAULT.
Cherie
Joe Dente wrote:
> registered.
> Joe
Re: Custom LayoutProviders [message #161528 is a reply to message #161321] Mon, 19 November 2007 16:18 Go to previous message
Ok, that makes sense.
I misunderstood the process/extension point. DEFAULT layout type is what
gets called by "Arrange All", so if you want your layout to override the
default behavior you return true when the layoutType equals DEFAULT.
Otherwise, your custom action can set the LayoutType and the provides()
method can figure out what to do.
Joe
"Cherie Revells" <crevells@ca.ibm.com> wrote in message
news:fhs6uu$8is$1@build.eclipse.org...
> Joe,
> happens when you invoke the "Layout Diagram as Square" menu item under the
> Sample menu. If you wanted to invoke your layout during an arrange all or
> arrange selected then you would contribute your layout provider when the
> Regards,
> Cherie
> Joe Dente wrote:
>> Hi,
>> debugger, I realized that the provides(IOperation operation) method on
>> SquareLayout is always returning false because it can only find the
>> DEFAULT layout:
>> and so layoutType always equals DEFAULT. If I understand this correctly,
>> it seems that the layoutProviders extension is the extension point for
>> anything, since even with the example plugin, only the default layout
>> ever gets registered.
>> Thanks,
>> Joe
Previous Topic:problem with nested figure
Next Topic:Error with diagram partitioning
Current Time: Tue Dec 02 23:31:14 EST 2025
Powered by FUDForum. Page generated in 0.07069 seconds
