Home » Eclipse Projects » GEF » auto-scrolling while DnD with ScalableRootEditPart
auto-scrolling while DnD with ScalableRootEditPart [message #161085] Thu, 09 December 2004 06:02 Go to next message
Originally posted by: rdenk.ftisoft.at
I am using a viewer of type ScrollinGraphicalViewer with a root edit part of
type ScalableRootEditPart. Now, i would like to have the same
'auto-scrolling' functionality while DnD as it is supported when using a
ScalableFreeformRootEditPart (when mouse is near viewer's borders, the pane
should scroll automatically).
Is there any way to achive this also with type ScalableRootEditPart or will
i have to implement this on my own (if so, what would be the best way to do
this)?
rde
p.s.: i do not want to use a ScalableFreeformRootEditPart as i do not edit
free formable content
Re: auto-scrolling while DnD with ScalableRootEditPart [message #161110 is a reply to message #161085] Thu, 09 December 2004 10:20 Go to previous messageGo to next message
I don't see the difference between these two roots. Abstract drop listener
will look for an auto expose helper on hover. This should be working in the
logic example.
"rdenk" <rdenk@ftisoft.at> wrote in message
news:cp9bcc$vt$1@www.eclipse.org...
of
pane
will
do
> this)?
> rde
Re: auto-scrolling while DnD with ScalableRootEditPart [message #161222 is a reply to message #161110] Fri, 10 December 2004 05:00 Go to previous messageGo to next message
In the logic editor example, of course it works, because they are using a
root edit part of type ScalableFreeformRootEditPart. But as far as i could
find out, a ScalableRootEditPart (which i would like to use) does not
support this auot-scrolling behaviour. This is also what they say in ibm
redbook sg246302, chapter 4.1.1 Root Edit Part
(http://www.redbooks.ibm.com/redbooks/pdfs/sg246302.pdf). You can see the
difference by having a look at the Flow Editor example; there they are using
a ScalableRootEditPart!
Wo what i would like to achieve is the scrolling behaviour of a freeform
root edit part, but WITHOUT the auto-expose behaviour (editor should not
expose unlimited in all directions).
any idea how to solve this?
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cp9qgl$j6q$1@www.eclipse.org...
listener
the
> logic example.
> > Hi,
part
> of
> pane
> will
> do
> > this)?
> > Thanks,
> > rde
edit
Re: auto-scrolling while DnD with ScalableRootEditPart [message #161229 is a reply to message #161222] Fri, 10 December 2004 07:45 Go to previous messageGo to next message
Just create your own subclass overwriting "getAdapter"
public Object getAdapter(Class adapter) {
if (adapter == AutoexposeHelper.class)
return new ViewportAutoexposeHelper(this);
return super.getAdapter(adapter);
You can create your own ViewportAutoexposeHelper if necessary.
Cu, Gunnar
Re: auto-scrolling while DnD with ScalableRootEditPart [message #161235 is a reply to message #161229] Fri, 10 December 2004 09:30 Go to previous messageGo to next message
created subclass from ScalableRootEditPart which implemented getAdapter()
method as mentioned, and it worked fine!
Thanks a lot!!!
"Gunnar Wagenknecht" <gunnar@wagenknecht.org> wrote in message
news:cpc5oe$fl9$1@www.eclipse.org...
a
could
the
using
> Cu, Gunnar
Re: auto-scrolling while DnD with ScalableRootEditPart [message #161380 is a reply to message #161235] Mon, 13 December 2004 11:21 Go to previous message
FreeformRootEditPart must replace the viewers Viewport to support freeform
function. The other root doesn't do this, so I guess that's why it doesn't
implement getAdapter...
The viewer should be involved similar to how reveal works. Open a bugzilla
so subclassing isn't required.
news:cpcbv3$4e4$1@www.eclipse.org...
> Thanks a lot!!!
using
> a
> could
ibm
> the
> using
> > Cu, Gunnar
Previous Topic:Automating Nightly Builds with PDE Build
Next Topic:GEF example without files
Current Time: Fri Jul 18 23:09:47 EDT 2025
Powered by FUDForum. Page generated in 0.04453 seconds
