Acceleo and Xtext metamodel [message #1611853] |
Wed, 11 February 2015 11:58  |
I have been trying to generate code for my own metamodel created in Xtext by Acceleo. However, I receive the following errors.
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.xml.sax.SAXParseExceptionpublicId: file:/C:/workspaces/URN/org.xtext.tgrl.samples/pkg01/p001.xgrl; systemId: file:/C:/workspaces/URN/org.xtext.tgrl.samples/pkg01/p001.xgrl; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:391)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:356)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:475)
at org.eclipse.acceleo.module.tgrl.main.Generate.<init>(Generate.java:90)
at org.eclipse.acceleo.module.tgrl.main.Generate.main(Generate.java:144)
Caused by: org.xml.sax.SAXParseExceptionpublicId: file:/C:/workspaces/URN/org.xtext.tgrl.samples/pkg01/p001.xgrl; systemId: file:/C:/workspaces/URN/org.xtext.tgrl.samples/pkg01/p001.xgrl; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:441)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:368)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1436)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:999)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:333)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 6 more
The steps I have followed:
- developed my xText language and installed it on my Eclipse. Now, I can work with my plugin. I can also see AST in the outline section.
- I created a small Acceleo project which creates a file without any consideration. When I run "generate.mtl" file inside of eclipse I receive the above error.
The Acceleo file is like this:
[comment encoding = UTF-8 /]
* The documentation of the module generate.
[module generate('http://www.xtext.org/grl/tgrl/TGRL')]
* The documentation of the template generateElement.
* @param aModel
[template public generateElement(aModel : Model)]
[comment @main/]
[file ('a.txt', false, 'UTF-8')]
This is an example.
[/file]
[/template]
I am sure that the Acceleo works fine because I applied the same process on UML and it worked.
In a topic, it's said there might be no "bin" folder but I checked I have.
Any help will be appreciated.
Thanks.
Re: Acceleo and Xtext metamodel [message #1612323 is a reply to message #1612279] |
Wed, 11 February 2015 19:07   |
I solved the issue. Thank you.
I write here the solution for the future reference.
What is needed is that just call doSetup() in two places
public Generate(URI modelURI, File targetFolder,
List<? extends Object> arguments) throws IOException {
TGRLStandaloneSetup.doSetup();
initialize(modelURI, targetFolder, arguments);
public Generate(EObject model, File targetFolder,
initialize(model, targetFolder, arguments);
Thanks.
FUDForum. Page generated in 0.26939 seconds
