Home » Modeling » EMF » [CDO] Need help resolving query latency
[CDO] Need help resolving query latency [message #1611782] Wed, 11 February 2015 11:07 Go to next message
Hello everybody,
we currently encounter some problems when executing queries from a client on a CDO server that is located in our local network. When executing arbitrary queries we experience latencies of approximatly 200ms, while executing the same queries on a server that is running on the same machine as the client only takes about 1-5ms. In both scenarios the database is located on the same machine as the server.
Does anyone of you have an idea where the packets might get stuck within the cdo/java stack and what can be done about it? Or are these query execution times considered normal when the packets go through the java tcp stack?
A few general information about our setup:
We are currently using CDO 4.3.0.v20140520-1823 and Java 1.8.0_31
Server and Client machines both run windows and firewalls are configured to allow communication on the cdo port.
To test general network latency we already performed a TCP latency test based on the powershell tool suite PSTools with 10000 iterations and a packet size of 50kB in our network and observed average roundtrip latencies of 5ms on packets send between the machines running the server and the client.
I have attached our cdo-server.xml and a minimal example which reproduces the latency in our setup.
Thank you in advance
Thomas Gerlitz
[Updated on: Wed, 11 February 2015 11:55] by Moderator
Re: [CDO] Need help resolving query latency [message #1611802 is a reply to message #1611782] Wed, 11 February 2015 11:19 Go to previous messageGo to next message
Hi Thomas,
Yes it is a known issue when the DB and the CDO server are on different
machines. The technical reason is that CDO make many SQL queries to get
CDORevisions. It's for that we advice to have both DB and CDO servers on
a same machine.
Best Regards.
Le 11/02/2015 17:07, Thomas Gerlitz a écrit :
> Hello everybody,
> we currently encounter some problems when executing queries on a CDO server that is located in our local network. When executing arbitrary queries we experience latencies of approximatly 200ms, while executing the same queries on a server that is running on the same machine only takes about 1-5ms.
> Thomas Gerlitz
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: [CDO] Need help resolving query latency [message #1611825 is a reply to message #1611802] Wed, 11 February 2015 11:37 Go to previous messageGo to next message
Hello Esteban,
thank you for your reply. It seams that I have not described my setup correctly:
We are currently using hsqldb that is started directly by the cdo server. Latencies (>200ms) can be observed when I use two machines in our setup. One running the cdo client application and one running the cdo server and the database.
When we move all these components (client,server and db) on the same machine we do not observe the described latencies.
I have now corrected this in my first post.
I hope these clarifications help to understand my problem.
Best Regards
Re: [CDO] Need help resolving query latency [message #1613059 is a reply to message #1611782] Thu, 12 February 2015 06:29 Go to previous messageGo to next message
Hello! To fix this, you should patch TCPAcceptor class.
In handleAccept method, add additional option:
socketChannel.socket().setTcpNoDelay(true);
This should work.
Re: [CDO] Need help resolving query latency [message #1614397 is a reply to message #1613059] Fri, 13 February 2015 03:08 Go to previous messageGo to next message
Hi Leonid and Thomas,
Interesting to know, looking at the CDO git history I see there was an
attempt to use this API for issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=213748 .
Best Regards.
> This should work.
Re: [CDO] Need help resolving query latency [message #1614438 is a reply to message #1614397] Fri, 13 February 2015 03:45 Go to previous messageGo to next message
In fact not, this bugzilla is about connection inactivity.
> Best Regards.
>> This should work.
Re: [CDO] Need help resolving query latency [message #1614459 is a reply to message #1611825] Fri, 13 February 2015 03:57 Go to previous messageGo to next message
Am 11.02.2015 um 17:37 schrieb Thomas Gerlitz:
> Hello Esteban,
I'd expect longer server round-trips if the server is not on the same machine. And 200ms sounds also reaonable to me. So
I'm not exactly sure about the problem. Am I missing something?
Cheers
/Eike
http://www.esc-net.de
> Best Regards
Re: [CDO] Need help resolving query latency [message #1614470 is a reply to message #1614397] Fri, 13 February 2015 04:06 Go to previous messageGo to next message
Hi Leonid and Esteban,
thank you for your replies. I tried the workaround that Leonid suggested and query execution times are now in the range of my initial setup (1-5ms).
Thank you very much for your help!
Best Regards
Re: [CDO] Need help resolving query latency [message #1614477 is a reply to message #1614470] Fri, 13 February 2015 04:10 Go to previous messageGo to next message
Am 13.02.2015 um 10:06 schrieb Thomas Gerlitz:
That is interesting! Maybe you want to submit an enhancement request so that we can investigate how to make this
configurable...
Cheers
/Eike
Re: [CDO] Need help resolving query latency [message #1614522 is a reply to message #1614477] Fri, 13 February 2015 04:51 Go to previous message
Hi Eike,
I have opened an enhancement request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=459861
Best regards
Previous Topic:Custom Attributes to Enum
Next Topic:Generated Code - Autoboxing Warnings
Current Time: Thu Jul 24 21:21:47 EDT 2025
Powered by FUDForum. Page generated in 1.05909 seconds
