Home » Modeling » EMF » [CDO/Net4j] How to properly authenticate
[CDO/Net4j] How to properly authenticate [message #1611344] Wed, 11 February 2015 04:59 Go to next message
Dear community,
I want to use a Net4j TCP connection with authentication in my client-server-application. I wire container manually for more control, like that:
IManagedContainer container = ContainerUtil.createContainer();
Net4jUtil.prepareContainer(container);
TCPUtil.prepareContainer(container);
How do I plug a security mechanism in there? I tried some things with UserManager and ChallangeNegogiation but got no luck.
I saw some documentation using post processing but I would like to have the authentication at connection time, not afterwards if possible.
I also read some test which referred to internal implementations but there should be another way I think.
Thanks in advance.
Re: [CDO/Net4j] How to properly authenticate [message #1614290 is a reply to message #1611344] Fri, 13 February 2015 01:29 Go to previous messageGo to next message
Hi Maximilian,
On the server-side you need to register a factory for an authenticator that implements
org.eclipse.net4j.util.security.IAuthenticator or org.eclipse.net4j.util.security.IAuthenticator2 (please have a look at
the implementations that we provide). This can either be done programatically via
org.eclipse.emf.cdo.server.ISessionManager.setAuthenticator(IAuthenticator) or declaratively by contributing an
org.eclipse.net4j.util.security.AuthenticatorFactory to the server's IManagedContainer.
On the client-side you must use
org.eclipse.emf.cdo.session.CDOSessionConfiguration.setCredentialsProvider(IPasswordCredentialsProvider). Again, you can
extend our implementations or make your own.
Cheers
/Eike
http://www.esc-net.de
Am 11.02.2015 um 15:46 schrieb Maximilian Kürth:
> Dear community,
> luck.
> Thanks in advance.
Re: [CDO/Net4j] How to properly authenticate [message #1632512 is a reply to message #1614290] Tue, 24 February 2015 05:12 Go to previous messageGo to next message
Hi Eike,
thanks for your response. The problem is that I do not use CDO at this stage of my application. I really like to put some more communication in one single container so i tried this one.
container.registerFactory(new MyNegotiatorFactory());
After that i took out the element like the IAcceptor before unless my factory would not be used.
container.getElement("org.eclipse.net4j.Negotiators", "challenge", null);
And my factory looks like this one.
public ChallengeNegotiator create(String description) throws productCreationException {
	System.out.println("negogiator plugged");
	users.addUser("peter", "kilometer".toCharArray());
	ChallengeNegotiator neg = new ChallengeNegotiator();
	neg.setUserManager(users);
	neg.setRandomizer(new Randomizer());
	return neg;
I simply extended the ChallengeNegotiatorFactory with the method above and it is really called and created (see the debug line, it is displayed).
On the client side I currently changed nothing to test the authentication (which in my oppinion should result in a failure). I implemented a simple PING-PONG-protocol and it works like I had no negotiator.
So beside CDO what should I change to allow only valid authenticated connections?
Re: [CDO/Net4j] How to properly authenticate [message #1632527 is a reply to message #1632512] Tue, 24 February 2015 05:24 Go to previous messageGo to next message
Am 24.02.2015 um 11:12 schrieb Maximilian Kürth:
> Hi Eike,
I really don't understand what that all means.
In my first reply I told you how to configure CDO authentication. What you're trying nevertheless (i.e., Net4j-level
single-sign-on authentication) is kind of deprecated and will probably not work. Here's additional information:
https://wiki.eclipse.org/Use_CDO_Net4J_Authentification#CDO_3.0
Cheers
/Eike
> @Override
> return neg;
Re: [CDO/Net4j] How to properly authenticate [message #1632547 is a reply to message #1632527] Tue, 24 February 2015 05:38 Go to previous messageGo to next message
Ok, I try some more detail.
I work on a RCP application which should be extenden in communication aspects. We use CDO as model repository and I would like to get a startup sequence like described like that:
- start client
- connect to server using authentication
- handle a permanent pinging connection (like client is alive)
- handle some security/licensing stuff
- establish cdo connection (after all other tasks already successfully done)
- -> work on client
Currently CDO is treated as an option beside some other stores so I tried to handle the essential network stuff using only Net4J.
I hope I could describe the situation.
Re: [CDO/Net4j] How to properly authenticate [message #1632572 is a reply to message #1632547] Tue, 24 February 2015 05:55 Go to previous messageGo to next message
Am 24.02.2015 um 11:38 schrieb Maximilian Kürth:
> - start client
> - -> work on client
> only Net4J.
Maybe it helps to compare your solution with the code in org.eclipse.net4j.util.tests.SecurityTest.
Cheers
/Eike
Re: [CDO/Net4j] How to properly authenticate [message #1632573 is a reply to message #1632572] Tue, 24 February 2015 05:58 Go to previous messageGo to next message
Am 24.02.2015 um 11:55 schrieb Eike Stepper:
Probably more realistic: org.eclipse.net4j.tests.TCPConnectorTest
Cheers
/Eike
Re: [CDO/Net4j] How to properly authenticate [message #1632844 is a reply to message #1632573] Tue, 24 February 2015 09:17 Go to previous messageGo to next message
I will try to dig a bit more into that but as I mentioned in the first comment there seems to be a lot of internal code usage. Anyway you will hear from me.
Re: [CDO/Net4j] How to properly authenticate [message #1632886 is a reply to message #1632844] Tue, 24 February 2015 09:46 Go to previous messageGo to next message
Am 24.02.2015 um 15:17 schrieb Maximilian Kürth:
> code usage.
What internal code usage? Where is it mentioned?
Cheers
/Eike
Re: [CDO/Net4j] How to properly authenticate [message #1632974 is a reply to message #1632886] Tue, 24 February 2015 10:52 Go to previous messageGo to next message
Ok, I think internal is the wrong word. I would consider restricted code to be better.
Examples are TCPConnector and TCPAcceptor.
Re: [CDO/Net4j] How to properly authenticate [message #1637181 is a reply to message #1632974] Thu, 26 February 2015 10:30 Go to previous messageGo to next message
Ok, I did the following to get it working.
private void startServer() throws InterruptedException {
	IBufferPool bPool = Net4jUtil.createBufferPool();
	LifecycleUtil.activate(bPool);
	UserManager uManager = new UserManager();
	uManager.addUser("peter", "kilometer".toCharArray());
	uManager.activate();
	container.registerFactory(new RandomizerFactory());
	container.registerFactory(new ChallengeNegotiatorFactory());
	container.registerFactory(new ActivityServerProtocol.Factory());
	container.activate();
	ITCPAcceptor acceptor = null;
	Randomizer randomizer = null;
	ChallengeNegotiator negotiator = null;
	try {
		acceptor = (ITCPAcceptor) container.getElement("org.eclipse.net4j.acceptors", "tcp", "127.0.0.1:2036",
				false);
		randomizer = (Randomizer) container.getElement("org.eclipse.net4j.randomizers", "default", null);
		negotiator = (ChallengeNegotiator) container.getElement("org.eclipse.net4j.Negotiators", "challenge", null,
				false);
		negotiator.setRandomizer(randomizer);
		negotiator.setUserManager(uManager);
		((TCPAcceptor) acceptor).getConfig().setBufferProvider(bPool);
		((TCPAcceptor) acceptor).getConfig().setNegotiator(negotiator);
		randomizer.activate();
		negotiator.activate();
		LifecycleUtil.activate(acceptor);
		while (true) {
			Thread.sleep(5000);
			for (IConnector connector : acceptor.getAcceptedConnectors()) {
				System.out.println(connector.openChannel().getUserID());
	} finally {
		if (randomizer != null) {
			randomizer.deactivate();
		if (negotiator != null) {
			negotiator.deactivate();
		if (acceptor != null) {
			LifecycleUtil.deactivate(acceptor);
		LifecycleUtil.deactivate(container);
		uManager.deactivate();
		LifecycleUtil.deactivate(bPool);
private void startClient() throws RemoteException, Exception {
	PasswordCredentialsProvider credentials = new PasswordCredentialsProvider("peter", "kilometer");
	LifecycleUtil.activate(credentials);
	container.registerFactory(new ResponseNegotiatorFactory());
	ITCPConnector connector = null;
	ResponseNegotiator negotiator = null;
	try {
		connector = (ITCPConnector) container.getElement("org.eclipse.net4j.connectors", "tcp", "127.0.0.1:2036",
				false);
		negotiator = (ResponseNegotiator) container.getElement("org.eclipse.net4j.Negotiators", "response", null,
				false);
		negotiator.setCredentialsProvider(credentials);
		((TCPConnector) connector).getConfig().setNegotiator(negotiator);
		LifecycleUtil.activate(connector);
		while (connector != null) {
			ActivityClientProtocol protocol = new ActivityClientProtocol(connector);
			ActivityRequest request = new ActivityRequest(protocol, "Client Peter Kilometer requesting...");
			String echo = request.send();
			protocol.close();
			if (!"OK".equals(echo)) {
				throw new RuntimeException("Server is not there!");
			System.out.println(echo + " " + connector.openChannel().getUserID());
			Thread.sleep(5000);
	} finally {
		if (connector != null) {
			LifecycleUtil.deactivate(connector);
		LifecycleUtil.deactivate(credentials);
However is there any possibility to configure the ITCPAcceptor and ITCPConnector correctly without accessing them through their implementations? Maybe something like ChallengeNegotiatorConfigurer though it is not sufficient at all. I really would like to prevent using restricted code.
Re: [CDO/Net4j] How to properly authenticate [message #1637189 is a reply to message #1637181] Thu, 26 February 2015 10:37 Go to previous message
Am 26.02.2015 um 16:30 schrieb Maximilian Kürth:
Very good ;-)
You should cast to ITransportConfigAware.
Cheers
/Eike
Previous Topic:[CDO] 2 clients / 2 JVM/ 1 collection / multiple set -> Java.lang.IllegalStateException
Next Topic:[Compare] Understanding the comparison panes
Current Time: Sat Jul 26 08:57:16 EDT 2025
Powered by FUDForum. Page generated in 0.06637 seconds
