Home » Eclipse Projects » Subversive » Can't merge
Can't merge [message #16106] Wed, 16 April 2008 21:07 Go to next message
Just tried to "merge" a project with another branch, but got this error:
Merge status operation failed.
svn: Requested SVNAdmin functionality is not yet implemented
Does this look like a problem with Subversive, SVN Kit, or the svn
repository?
Re: Can't merge [message #16415 is a reply to message #16106] Wed, 16 April 2008 23:12 Go to previous messageGo to next message
If I switch from SVN Kit 1.2 to JavaHL 1.5.0 I don't get this error, but a
"no changes in merge" message (even though there are changes for sure)...
Re: Can't merge [message #16451 is a reply to message #16415] Thu, 17 April 2008 04:50 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Eric,
Could you please specify what versions of Subversive and SVN connectors
are installed in your Eclipse IDE instance?
As I see from the code of SVN Kit 1.2.0 which is used in latest available
build it should not throw exceptions like:
Also we found issue in merge, if property in conflict: in that case
resource does not recognized as changed. So, fix for the last problem
which I describes will be available in the next Subversive build
(approximately at the end of next week).
P.S.
As temporary workaround you can use merge without UI extensions. In order
to disable UI please switch off option at:
Window->Preferences->Team->SVN->SVN Connector->Use SVN Merge view
Re: Can't merge [message #16569 is a reply to message #16451] Thu, 17 April 2008 22:58 Go to previous messageGo to next message
Subversive 0.7.0
SVN Kit 1.2.0 alpha
JavaHL1.5.0 alpha2
Great!
> P.S.
Re: Can't merge [message #16619 is a reply to message #16569] Fri, 18 April 2008 09:10 Go to previous message
Eric Jain wrote:
> Subversive 0.7.0
> SVN Kit 1.2.0 alpha
> JavaHL1.5.0 alpha2
Yes, definitely your Subversive instance needs to be updated. I think the
best time to do this is the moment of next Subversive build publishing,
regarding to merge-related fixes.
Previous Topic:svn copy
Next Topic:Subversive & merges
Current Time: Fri Jul 18 13:46:47 EDT 2025
Powered by FUDForum. Page generated in 0.05347 seconds
