Home » Modeling » GMF (Graphical Modeling Framework) » two links being shown when diagrams are connected
two links being shown when diagrams are connected [message #160158] Wed, 14 November 2007 02:56 Go to next message
hi all
in my gmf project when i try to connect two diagrams it shows to links.
but i want one link ..
plz help me
thanks
Govind R.
Re: two links being shown when diagrams are connected [message #160197 is a reply to message #160158] Wed, 14 November 2007 05:52 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
govind wrote:
> hi all
What do you mean by connect two diagrams. Do you mean figures? - In that
case you must specify in gmfgraph that you only want one of the links to
show graphically.
HTH,
Tomas Zijdemans
> plz help me
> thanks
> Govind R.
Re: two links being shown when diagrams are connected [message #160281 is a reply to message #160197] Wed, 14 November 2007 08:59 Go to previous messageGo to next message
Originally posted by: govind.ashrit.xxx.com
thanks..
but where exactly it will be..(as i am new to gmf)
can be bit in detail.
Thanks and Regards
Govind R
Re: two links being shown when diagrams are connected [message #160305 is a reply to message #160197] Wed, 14 November 2007 09:05 Go to previous messageGo to next message
hi..
i need to connect figures..
i think we need to specify in the gmfmap???
but where exactly in that.
Govind R.
Re: two links being shown when diagrams are connected [message #160394 is a reply to message #160305] Wed, 14 November 2007 10:21 Go to previous messageGo to next message
govind wrote:
> hi..
You should really look in the tutorial, depending on your knowledge. In
gmfgraph you specify graphical element (including links). In gmfmap you
combine the graphics with tools. Then you generate. But again, this is
all covered in the tutorial:
http://wiki.eclipse.org/GMF_Tutorial
HTH,
Tomas Zijdemans
Re: two links being shown when diagrams are connected [message #160508 is a reply to message #160394] Thu, 15 November 2007 00:00 Go to previous messageGo to next message
hi..
I have gone through documentation.
Let me explain..
In my project i have many figures
for ex:
fig1,fig2,fig3,fig4 etc.
when i connect fig 1 and fig 2 it creates a single connection.
my project has feature where in i can add fig 1 and fig2 in fig3
and when i try to connect fig1 and fig2 which are now in fig3 .it shows
two connections ..
hope i am clear
Govind R.
Re: two links being shown when diagrams are connected [message #160520 is a reply to message #160508] Thu, 15 November 2007 01:37 Go to previous messageGo to next message
Originally posted by: biju_gopinathan.rediffmail.com
Hi Govind,
Check the following bug: this may help you
https://bugs.eclipse.org/bugs/show_bug.cgi?id=148021
Regards, Biju
govind wrote:
> hi..
> Let me explain..
> for ex:
> two connections ..
> hope i am clear
> Regards
> Govind R.
Re: two links being shown when diagrams are connected [message #160831 is a reply to message #160520] Fri, 16 November 2007 03:44 Go to previous messageGo to next message
biju wrote:
> Hi Govind,
> Regards, Biju
> govind wrote:
>> hi..
>> Let me explain..
>> for ex:
>> two connections ..
>> hope i am clear
>> Regards
>> Govind R.
hi biju..
i gone through through that..
i couldn't get any clues...
Govind R.
Re: two links being shown when diagrams are connected [message #160864 is a reply to message #160831] Fri, 16 November 2007 06:51 Go to previous messageGo to next message
Hi govind,
Did you try overriding:
CanonicalEditPolicy.shouldHandleNotificationEvent()return false;
Biju
govind wrote:
> biju wrote:
>> Hi Govind,
>> Regards, Biju
>> govind wrote:
>>> hi..
>>> Let me explain..
>>> for ex:
>>> shows two connections ..
>>> hope i am clear
>>> Regards
>>> Govind R.
> hi biju..
> Regards
> Govind R.
Re: two links being shown when diagrams are connected [message #162104 is a reply to message #160864] Thu, 22 November 2007 11:11 Go to previous messageGo to next message
hi biju
Actually i dont have any method as shouldHandleNotificationEvent();
or if it has to be explicitly added..
Please help in this regard
Govind R
Re: two links being shown when diagrams are connected [message #162218 is a reply to message #162104] Fri, 23 November 2007 04:07 Go to previous messageGo to next message
Hi Govind,
Check your edit policies, and look for one edit policy which
extends CanonicalConnectionEditPolicy, (That is, The CanonicalEditPolicy
of the container of your links). And there will only be one class that
extends CanonicalConnectionEditPolicy for your digram. In that class
overwirde CanonicalEditPolicy.shouldHandleNotificationEvent(), and
return false;
It worked for me earlier, when I faced the same problem, hope
it helps you.
Cheers, Biju
govind wrote:
> hi biju
> Regards
> Govind R
Re: two links being shown when diagrams are connected [message #162627 is a reply to message #162218] Sun, 25 November 2007 22:21 Go to previous messageGo to next message
hi..biju
i did the same as u told.. its working,,,,
Thanks a lot...
looking forward for help from u...in future if required....
Thanks & Regards
Govind R.
Re: two links being shown when diagrams are connected [message #1783318 is a reply to message #162627] Sun, 11 March 2018 22:09 Go to previous messageGo to next message
i met the same question and i do not find some class extends CanonicalEditPolicy with the connection , and when i use this connection it report some mistakes in console : java.lang.IllegalArgumentException: Argument not valid
i do not know how to deal with this problem
Re: two links being shown when diagrams are connected [message #1783319 is a reply to message #1783318] Sun, 11 March 2018 22:38 Go to previous message
i modified all the CanonicalEditPolicy in .diagram.edit.policies by adding ' protected boolean shouldHandleNotificationEvent(Notification event) {
return false;
} ' this sentence,it works!
the result is showing one link but it still report the errors in console 'java.lang.IllegalArgumentException: Argument not valid'
Previous Topic:Error message: Node is referenced from multiple containers with different 'List Layout' value
Next Topic:DiagramLinkStyle example
Current Time: Sat Jul 19 12:27:54 EDT 2025
Powered by FUDForum. Page generated in 0.06747 seconds
