| No Display.getCurrent() when opening Swing Component [message #160645] |
Mon, 06 December 2004 14:57  |
(already posted to eclipse.platform.swt - they sent me to this group)
I have a (SWT based) GEF/draw2d application which opens a JFrame on
button click (pure Swing, not SWT_AWT !)
Beside from strange effects like deadlocks when using the Clipboard if
the JFrame is opened modal, I've got one somehow fundamental error:
The JFrame is opened, causing some visuals "from behind" to be marked as
invalid. The asynchronous (GEF-) repaint manager triggers something like
a repaint event with "Display.getCurrent().asyncExec(....)", which
results in a NullPointerException...
Is there no current display, if some Swing component has the focus ?
It sound plausible, as the current thread is no SWT ui-thread anymore...
but how can I work around this issue?
Changing the call into "Display.getDefault()" is no solution, as the
code is part of the GEF.
Any ideas ?
Thanks in advance
Florian
| Re: No Display.getCurrent() when opening Swing Component [message #160766 is a reply to message #160734] |
Tue, 07 December 2004 07:49  |
Florian Georg schrieb:
> Here's the stacktrace.
Your are right, the current thread is the AWT event thread and not the
SWT thread. You just need to ensure that you are updating your figures
inside the SWT thread.
Use Display#syncExec/asyncExec(Runnable) when posintg events to the UI
(eg. when calling FlowNodeEditPart#updateControlBar).
Cu, Gunnar
FUDForum. Page generated in 0.04124 seconds
