Home » Language IDEs » Java Development Tools (JDT) » Setting breakpoints in M9
Setting breakpoints in M9 [message #160580] Tue, 25 May 2004 10:16 Go to next message
I have difficulties setting breakpoints with M9. Is this already known or
should I file a bug report?
Jochen
!ENTRY org.eclipse.jdt.debug.ui 4 150 Mai 25, 2004 16:24:28.51
!MESSAGE Internal Error
!STACK 0
org.eclipse.jface.text.BadLocationException
at
org.eclipse.jface.text.AbstractLineTracker.getLineInformatio n(AbstractLineTracker.java:198)
at
org.eclipse.jface.text.AbstractDocument.getLineInformation(A bstractDocument.java:786)
at
org.eclipse.jdt.internal.debug.ui.actions.ManageBreakpointRu lerAction.run(ManageBreakpointRulerAction.java:100)
at
org.eclipse.ui.texteditor.AbstractRulerActionDelegate.run(Ab stractRulerActionDelegate.java:98)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:276)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:899)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:850)
at
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:769)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2716)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2382)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1363)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1334)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:253)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:97)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:307)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
Re: Setting breakpoints in M9 [message #160614 is a reply to message #160580] Tue, 25 May 2004 11:18 Go to previous messageGo to next message
Originally posted by: user.domain.invalid
I think that's already known. Try 2x clicking on the left bar or doing
ctrl-shift-B. It's contextual menu that's broke.
Jochen Wiedmann wrote:
> Regards,
> Jochen
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Setting breakpoints in M9 [message #160648 is a reply to message #160614] Tue, 25 May 2004 13:37 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=62266
"exquisitus" <user@domain.invalid> wrote in message
news:c8vnlk$lpe$2@eclipse.org...
> > Hi,
or
> > Regards,
> > Jochen
> > !STACK 0
> > at
acker.java:198)
> > at
java:786)
> > at
> > at
nDelegate.java:98)
> > at
> > at
> > at
tem.java:850)
> > at
tionItem.java:769)
> > at
> > at
> > at
java:307)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: Setting breakpoints in M9 [message #160663 is a reply to message #160648] Tue, 25 May 2004 12:59 Go to previous message
Ah, code folding at play here. It does seem if you turn off code
folding the contextual menu works.
>>>Hi,
> or
>>>Regards,
>>>Jochen
>>>!STACK 0
>>>at
> acker.java:198)
>>>at
> java:786)
>>>at
>>>at
> nDelegate.java:98)
>>>at
>>>at
>>>at
> tem.java:850)
>>>at
> tionItem.java:769)
>>>at
>>>at
>>>at
> java:307)
>>>at
>>>at
Previous Topic:Adding jars in classpath from project directory shows added jars also
Next Topic:the mnemonic 's' in menu "Run" is not unique since M9
Current Time: Sat Jul 26 20:28:33 EDT 2025
Powered by FUDForum. Page generated in 0.03339 seconds
