Home » Archived » BIRT » WebViewer and Charts
WebViewer and Charts [message #160291] Thu, 11 May 2006 09:22 Go to next message
Originally posted by: maxence.delaune.gmail.com
Hi everybody.
First of all, there is my config:
* BIRT webviewer version 2.0.1
* Tomcat 4.1
* JDK 1.4.0_01-b03
I try without success to run charts in webviewer. In Eclipse, they work correctly but when I deploy my report (xxx.rptdesign) on my tomcat, I can see an error:
Exception in:
soapenv:Server.userException
I've also try on the TEST MySQL Database given with the BIRT Tutorialnamed "ChartingExampleAfter" but it don't work also.
All my report without charts working good.
Help, please.
Re: WebViewer and Charts [message #160317 is a reply to message #160291] Thu, 11 May 2006 09:40 Go to previous messageGo to next message
Did you read the integration section on the website?
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
Do you have a temp folder under your Tomcat installation? If not you should
create one, but normally it should be there.
David
"DELAUNE" <maxence.delaune@gmail.com> wrote in message
news:32532677.1147353781006.JavaMail.root@cp1.javalobby.org...
> Hi everybody.
> * Tomcat 4.1
> * JDK 1.4.0_01-b03
> see an error:
> Exception in:
> Help, please.
Re: WebViewer and Charts [message #160348 is a reply to message #160317] Thu, 11 May 2006 10:16 Go to previous messageGo to next message
Thank, but I've this 'temp' directory under my Tomcat, it create empty GIF file (size=0 kb).
For the instruction about iText.jar and prototype.js, I've do it before. I've also read a lot of newsgroup. But I've found nowhere the solution to my problem so I've try to explain it here.
An other idea ? :-)
Re: WebViewer and Charts [message #160356 is a reply to message #160348] Thu, 11 May 2006 10:44 Go to previous messageGo to next message
Are you on Linux or windows? Did you modify the example code or not?
David
news:27915694.1147357018773.JavaMail.root@cp1.javalobby.org...
> file (size=0 kb).
> An other idea ? :-)
Re: WebViewer and Charts [message #160462 is a reply to message #160356] Thu, 11 May 2006 15:53 Go to previous messageGo to next message
Eclipse is on a window, but the web viewer is under linux.
I haven't modified the code.....
Re: WebViewer and Charts [message #160471 is a reply to message #160462] Thu, 11 May 2006 16:06 Go to previous messageGo to next message
Did you try to run in headless mode the webviewer? This is a common issue on
Linux.
Set this in the java command line:
-Djava.awt.headless=true
David
news:3394749.1147377239657.JavaMail.root@cp1.javalobby.org...
Re: WebViewer and Charts [message #160566 is a reply to message #160471] Fri, 12 May 2006 02:29 Go to previous messageGo to next message
IT is the solution.
It works correctly now.
Thanks for your help David.
Re: WebViewer and Charts [message #160626 is a reply to message #160566] Fri, 12 May 2006 06:55 Go to previous message
Originally posted by: gandhimathi.p.gmail.com
Wow,Its Working out ... I hav been digging for this only...
Thanks David..
Thanks a lot
Mathi
Previous Topic:Is there any way to display charts at run-time
Next Topic:Defining a scriplet dataset, that displays List of Items
Current Time: Thu Nov 06 02:59:25 EST 2025
Powered by FUDForum. Page generated in 0.04252 seconds
