Home » Eclipse Projects » GEF » Extending FlowFigure
Extending FlowFigure [message #160111] Thu, 02 December 2004 11:16 Go to next message
Originally posted by: none.none.com
I am trying to extend FlowFigure to simulate a flow layout similar to html,
where the text could wrap to the next line (like TextFlow does, when inside
PageFlow). I need to mix text (inline or block) with other kinds of controls
(always block).
I can't afford to have all my figures extend FlowFigure, so instead I
created a generic class FlowFigureLeaf that derives from FlowFigure and acts
as a container of any single Figure. My problem is how to implement this
FlowFigureLeaf to have its child figure render/layout properly, so far the
FlowFigure mechanisms remain cryptic and it doesn't work. Any
hint/suggestion would be welcomed. Do I need a FlowLayoutManager or not? If
yes what would it need to do, if not what should the FlowFigureLeaf.layout
function do? FlowFigureLeaf has only one child, and it's not a FlowFigure,
but any generic Figure.
David
Re: Extending FlowFigure [message #160119 is a reply to message #160111] Thu, 02 December 2004 11:39 Go to previous messageGo to next message
You want to create a wrapper flow figure capable of wrapping any generic
figure.
This shouldn't be hard. Create a flowwrapper which when it lays out,
constructs a box with the desired width and height for the normal inner
figure. If you want the figure to fill up the containing block, you can
request a newline, then get the amount of available space on the newline,
and use that as the box's width. Then add the box to the current line, and
endline again. On postlayout, your box will be adjusted (although probably
it won't move since it fills block width), then you just reposition the
wrapped figure to be inside the box.
"David Michonneau" <none@none.com> wrote in message
news:conf5d$rfq$1@www.eclipse.org...
html,
inside
controls
> (always block).
acts
If
> David
Re: Extending FlowFigure [message #160187 is a reply to message #160119] Thu, 02 December 2004 15:00 Go to previous messageGo to next message
I'm doing something like this, but it only creates a small box, although
when I debug I can see the width and height in this code is correct. Am I
missing anything?
class WrapperFigure{
protected void layout()
context.endLine();
int width = context.getCurrentLine().getAvailableWidth();
int height = context.getCurrentLine().getHeight();
box.setWidth ( width);
box.setHeight ( height );
context.getCurrentLine().add(box);
context.endLine();
* @see org.eclipse.draw2d.text.FlowFigure#postValidate()
public void postValidate()
Rectangle r = new Rectangle(box.x, box.y, box.getWidth(),
box.getHeight()) ;
Dimension figureSize =
figure.getPreferredSize(box.getWidth(),box.getHeight());
// set bounds of child
figure.setBounds(new Rectangle(box.x, box.y, figureSize.width,
figureSize.height));
"Randy Hudson" <none@us.ibm.com> wrote in message
news:congfk$uo7$1@www.eclipse.org...
> figure.
> and
> probably
>> Hi,
> html,
> inside
> controls
>> (always block).
> acts
>> the
> If
>> FlowFigure,
>> Thanks,
>> David
Re: Extending FlowFigure [message #160218 is a reply to message #160187] Thu, 02 December 2004 15:53 Go to previous messageGo to next message
Probably the wrapper figure needs to update its own bounds as well.
Re: Extending FlowFigure [message #160368 is a reply to message #160218] Fri, 03 December 2004 12:29 Go to previous messageGo to next message
Thanks, that took care of it!
And now another issue... the layout function is called three times, and for
some unknown reason, it causes the first line to be empty, but with the size
of the element on the next line. I am not sure why the FlowPageLayout
manager calls layoutChildren since the children are going to be layed out
anyway by the validate call, but I guess there is a reason. If I don't set a
height to the box I add, all my lines are of height 0. Any idea of what
could be wrong?
David
news:convbr$30s$1@www.eclipse.org...
Re: Extending FlowFigure [message #160416 is a reply to message #160368] Fri, 03 December 2004 15:40 Go to previous messageGo to next message
The multiple layouts are probably because of multiple width hints being
used. One is without the vertical scrollbar present, and one with. The 3rd
layout is probably to undo the 2nd (if the scrollbar isn't actually needed).
BTW, the preferred sizes of a flowpage get cached by width hint, so you
shouldn't see so many layout every time.
As far as empty lines, etc., I don't have enough info to know what is
happening.
news:coq7p5$2jv$1@www.eclipse.org...
for
size
a
The reason is to respond to the getPreferredSize request
> could be wrong?
> David
Re: Extending FlowFigure [message #161250 is a reply to message #160416] Fri, 10 December 2004 10:26 Go to previous messageGo to next message
The problem is when layout is called multiple lines, it keeps doing
context.endLine();
context.getCurrentLine.add(box);
context.endLine();
then the getCurrentLine gets the next line based on the height of the box in
the first line... The box is added to each line, creating this gap. How can
I avoid that?
David
news:coqivk$s63$1@www.eclipse.org...
> 3rd
> needed).
> happening.
> for
> size
>> set
> a
>> could be wrong?
>> Thanks,
>> David
Re: Extending FlowFigure [message #161268 is a reply to message #161250] Fri, 10 December 2004 14:01 Go to previous messageGo to next message
Finally what I did was to change flowpage validate() method:
public void validate() {
if (isValid())
return;
setValid(true);
layout(); // instead of calling super.validate();
postValidate();
if it calls super.validate like in the original implementation, that calls
validate on all children, and their layout function as well, which is bad
since it won't clean-up the context after calling it. We don't really need
to call validate on children, since it's done in layout() by
layoutChildren().
What do you think about that?
David
news:cpcf6a$fhc$1@www.eclipse.org...
> context.endLine();
> context.endLine();
> in the first line... The box is added to each line, creating this gap. How
> can I avoid that?
> David
>> 3rd
>> needed).
>> happening.
>> for
>> size
>>> out
>>> set
>> a
>>> could be wrong?
>>> Thanks,
>>> David
Re: Extending FlowFigure [message #161432 is a reply to message #161268] Mon, 13 December 2004 11:36 Go to previous messageGo to next message
I don't have any test cases where layouts occur twice (without invalidates()
coming between them). super.validate() should basically do nothing since
the children are valid at that point, so a workaround isn' required.
news:cpcrq2$o7s$1@www.eclipse.org...
> if (isValid())
> return;
> setValid(true);
> postValidate();
> layoutChildren().
> David
> > context.endLine();
> > context.endLine();
box
How
> > can I avoid that?
> > Thanks,
> > David
The
> >> 3rd
> >> needed).
> >> happening.
and
> >> for
the
> >> size
> >>> out
> >>> set
> >> a
what
> >>> could be wrong?
> >>> Thanks,
> >>> David
Re: Extending FlowFigure [message #161464 is a reply to message #161432] Mon, 13 December 2004 12:48 Go to previous messageGo to next message
It seems the child of flowpage gets invalid in postvalidate(), causing it to
layout again.
postvalidate()
figure.setBounds(bounds); // figure is the child of the wrapper
flowfigure)
this.setBounds(bounds);
actually there is a new scenario where it happens: when I add a child to the
enclosed figure, it again calls validate too many times, am I doing
something wrong?
David
news:cpkgdr$289$1@www.eclipse.org...
>invalidates()
>> if (isValid())
>> return;
>> setValid(true);
>> postValidate();
>> calls
>> need
>> layoutChildren().
>> Thanks,
>> David
>> > context.endLine();
>> > context.endLine();
> box
> How
>> > can I avoid that?
>> > Thanks,
>> > David
>> >> being
> The
>> >> 3rd
>> >> needed).
>> >> you
>> >> happening.
> and
>> >> for
> the
>> >> size
>> >>> out
>> >>> don't
>> >>> set
>> >> a
> what
>> >>> could be wrong?
>> >>> Thanks,
>> >>> David
Re: Extending FlowFigure [message #161487 is a reply to message #161464] Mon, 13 December 2004 14:45 Go to previous messageGo to next message
Maybe you are nesting flowpages? I don't see that code and comment in my
FlowPage postValidate() method.
Try posting a snippet of code which shows the problem.
news:cpkkm9$gb4$1@www.eclipse.org...
to
> layout again.
> postvalidate()
> flowfigure)
the
> something wrong?
> David
Re: Extending FlowFigure [message #161566 is a reply to message #161487] Wed, 15 December 2004 08:47 Go to previous message
The code below is my own code, which is triggering the figure to become
invalid. I have a flowwrapperfigure that contains a generic IFigure, should
I do the setBounds somewhere else? I thought it has to be done in
postvalidate?
David
news:cpkrhk$6h8$1@www.eclipse.org...
> to
>> layout again.
>> postvalidate()
>> flowfigure)
> the
>> something wrong?
>> Thanks,
>> David
Previous Topic:Problems with plugins
Next Topic:OutlineView refresh
Current Time: Wed Jul 30 17:45:19 EDT 2025
Powered by FUDForum. Page generated in 0.04314 seconds
