Home » Newcomers » Newcomers » Window Working Sets
Window Working Sets [message #160040] Mon, 10 July 2006 06:11 Go to next message
Originally posted by: michael.illgner.email.de
After using eclipse for nearly 5 years I am not really a newcomer ;-)
but may someone introduce me into the concept of a window working set or
show me a pointer to some documentation or tutorial for it. I do not see
any difference to a normal working set which I am using for a long time.
Thanks Michael
Re: Window Working Sets [message #160315 is a reply to message #160040] Tue, 11 July 2006 12:10 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
When you set the working set for a particular window, it will apply to
all views within that window (unless those views have been configured to
show a different working set). Think of it as pulling the concept of
working set from the view level up to the workbench window level.
Michael Illgner wrote:
> Thanks Michael
Re: Window Working Sets [message #160338 is a reply to message #160315] Tue, 11 July 2006 12:43 Go to previous messageGo to next message
>> Hi,
>> or show me a pointer to some documentation or tutorial for it. I do
>> not see any difference to a normal working set which I am using for a
>> long time.
>> Thanks Michael
A little background info might help:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=45212
Hope this helps,
Eric
Re: Window Working Sets [message #160435 is a reply to message #160315] Wed, 12 July 2006 05:59 Go to previous messageGo to next message
Does that imply when I use only one workbench window , I will not
see any difference ?
Michael
Re: Window Working Sets [message #160529 is a reply to message #160435] Wed, 12 July 2006 14:34 Go to previous message
No, each window can have its own working set. If you have one workbench
window, and you set the working set for that window, then that working
set will be applied to all views in that window.
Previous Topic:Preferences.xsd
Next Topic:Changing file:/// default with 'Open with Web Browser'
Current Time: Fri Oct 10 08:04:08 EDT 2025
Powered by FUDForum. Page generated in 0.13169 seconds
