| how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160243] |
Fri, 03 December 2004 00:39  |
Originally posted by: hitdemo2002.yahoo.com.cn
in GEF's example-logic i want to add some extrally function to deletion
action ,that is to say: when delete a model from a logicdiagram (or delete
a
figure from diagram), i can notified. and i can add some number to a
array(or some other function).
for implements this function ,does i must code a new deleteaction and
replace "IWorkbenchActionConstants.DELETE" with thest new action
or i can use some existed function such as performRequest in some
editpart??
| Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160288 is a reply to message #160243] |
Fri, 03 December 2004 02:13   |
> delete a
> editpart??
You can probably use performRequest or something similar to send
notificatoin of deletes. Depends on what you are listening too. You
could listen to the parent container, or the child being deleted itself.
Its up to you.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
| Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160336 is a reply to message #160311] |
Fri, 03 December 2004 09:41   |
>> itself. Its up to you.
> i have added a performRequest() to the xxxeditpart,
> public class xxxeditpart extends LogicEditPart {
> public void performRequest(Request req) {
> System.out.println("come
> in。。。。Ӎ 0;。。。。 ");
> if (req.getType() == RequestConstants.REQ_DELETE) {
> System.out.println(" deleting。。。。& ;#12290;。。。。 ");
> but i found that above code only took effect at the time of double click
> the xxxeditpart. it can't notified of deletion,resize,move etc,why?
What do you mean by took effect? Do you mean the only time that method
was called was during double click?
Also you should still be using .equals() rather than instance equality.
Respectfully,
CL Gilbert
and a robber."
| Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160447 is a reply to message #160336] |
Fri, 03 December 2004 20:26   |
> Respectfully,
> CL Gilbert
> and a robber."
what i mean is:
when i delete xxxeditpart use "del" key for popmenu, xxxeditpart's
performRequest
could't be called,because there were no print out message "come
in.........."
if i double click xxxeditpart , above mothod was called,so i was confused
by this method.
System.out.println("come in...........");
System.out.println("deleting..........");
| Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160615 is a reply to message #160311] |
Mon, 06 December 2004 12:06  |
PerformRequest is used for things which do not necessarily execute a
Command. For example, direct edit may go into an editing mode, but if the
user presses ESC, nothing happens. For actions which should simply execute
immediately, if executable, getCommand is the API of choice.
"hitdemo2002" <hitdemo2002@yahoo.com.cn> wrote in message
news:cop6v3$g6g$1@www.eclipse.org...
> > Its up to you.
in。。。。Ӎ 0;。。。。 ")
FUDForum. Page generated in 0.03289 seconds
