Problems in using MARTE NFPs with Papyrus 0.10 [message #1284565] |
Fri, 04 April 2014 12:16  |
I experiencing severe problems in applying types in MARTE_Library/BasicNFP_Types to attributes of my stereotypes. I have this problem since the first upgrade i made to Papyrus 0.10, time ago. I've already described these issues in an old post here:
https://www.eclipse.org/forums/index.php/m/1168538/#msg_1168538
I recently upgraded to Papyrus Kepler SR2a, according to this post: http://www.eclipse.org/forums/index.php/t/662007/
But at today, I'm still not able to create stereotypes with attributes having a type from MARTE_Library/BasicNFP_Types (e.g. NFP_Duration).
I attached a very minimal example that reproduces the problem. Try to save and define the profile. When I do this, I always get a "Profile definition failed" error.
Is someone else experiencing this problem? Is it a bug? Is someone working to fix it?
I'm getting really frustrated and hope someone can shed some light on this.
Matteo
[Updated on: Fri, 04 April 2014 12:17] by Moderator
Re: Problems in using MARTE NFPs with Papyrus 0.10 [message #1611792 is a reply to message #1599204] |
Wed, 11 February 2015 11:12  |
The Marte profile/library in Papyrus contains some errors. Since Kepler, Papyrus prevents definition of profiles with error, to avoid crashes when the invalid profile is applied.
You can bypass this validation by using the Eclipse/UML2 editor, and define your profile there (Using the menu "UML Editor > Profile > Define"). The profile can then be deployed and applied in Papyrus.
The right solution would of course to fix the issues in the Marte profile/library directly, but nobody's working on this profile ATM, so it is unlikely to happen.
Camille
FUDForum. Page generated in 0.04093 seconds
