Home » Eclipse Projects » e(fx)clipse » Jar file not running on double click.
Jar file not running on double click. [message #1589416] Wed, 28 January 2015 07:31 Go to next message
After building the javafx project I am getting the following ...
No base JDK. Package will use system JRE.
The jar libs\js-14.jar has a main class org.mozilla.javascript.tools.shell.Main that does not match the declared main com.msat.frameworks.keyword_driven.iaf.iAF_UI
The jar libs\selenium-server-standalone-2.35.0.jar has a main class org.openqa.grid.selenium.GridLauncher that does not match the declared main com.msat.frameworks.keyword_driven.iaf.iAF_UI
BUILD SUCCESSFUL
Total time: 4 seconds
The jar file gets created successfully. But it doesn't run on double click or even by using CMD prompt.
[Note: I have tried creating small applications without using external jars and they worked perfectly fine.]
I have attached the build.xml file.
Any help would be much appreciated. Thanks in advance.
  • Attachment: build.xml
    (Size: 7.33KB, Downloaded 233 times)
[Updated on: Thu, 29 January 2015 01:24] by Moderator
Re: Jar file not running on double click. [message #1592034 is a reply to message #1589416] Thu, 29 January 2015 17:06 Go to previous messageGo to next message
Did you try running on the console with java -jar which give you more
information what is wrong.
Tom
On 28.01.15 16:00, Swati Sharma wrote:
> I am facing a similar problem:
> BUILD SUCCESSFUL
Re: Jar file not running on double click. [message #1597598 is a reply to message #1592034] Mon, 02 February 2015 07:14 Go to previous messageGo to next message
Yes I did,
PFA the screenshot with the error details.
Swati
  • Attachment: Capture.PNG
    (Size: 43.93KB, Downloaded 311 times)
Re: Jar file not running on double click. [message #1597619 is a reply to message #1597598] Mon, 02 February 2015 07:32 Go to previous messageGo to next message
so
a) You miss to package your fxml-Files with the app
b) You are using relative paths in your java code who don't work in a
jar filesystem
What does the code look like iAF_UI.start()?
Tom
On 02.02.15 13:14, Swati Sharma wrote:
> Yes I did,
> Swati
Re: Jar file not running on double click. [message #1598806 is a reply to message #1597619] Tue, 03 February 2015 02:01 Go to previous messageGo to next message
Hi Tom,
The code in Main looks something like this:
public class iAF_UI extends Application {
public static int threadcount1;
public static String jarDir;
public static iAF_Controller controller;
private Stage stage;
private BorderPane root;
@Override public void start(final Stage stage) throws Exception {
CodeSource codeSource = iAF_UI.class.getProtectionDomain().getCodeSource();
File jarFile = new File(codeSource.getLocation().toURI().getPath());
jarDir = jarFile.getParentFile().getPath();
FXMLLoader loader = new FXMLLoader();
loader.setLocation(iAF_UI.class.getResource("iAF_GUI.fxml"));
root = (BorderPane) loader.load();
controller = (iAF_Controller)loader.getController();
controller.setMainApp(this);
Platform.setImplicitExit(false);
//stage.setMaximized(true);
stage.setTitle("IAF-Draft!");
stage.setScene(new Scene(root));
stage.initStyle(StageStyle.UNIFIED);
stage.getIcons().add(new Image(getClass().getResourceAsStream("logo.png")));
stage.show();
stage.setOnCloseRequest(new EventHandler<WindowEvent>() {
public void handle(WindowEvent t) {
Platform.exit();
System.exit(0);
public Stage getStage() {
return stage;
public static void main(String[] args) { launch(args); }
Swati
[Updated on: Tue, 03 February 2015 02:18] by Moderator
Re: Jar file not running on double click. [message #1598812 is a reply to message #1598806] Tue, 03 February 2015 02:07 Go to previous messageGo to next message
I would also like to bring this to your notice that I did create a few small applications before in which I created the package and called the fxml file in Main exactly the same way. They all seem to work perfectly fine.
The only difference i could see while building it, was all the external jar files that i added to this one.
And the following build error:
Do you think this could be the problem? If yes, what do you suggest I should do as i need these jar files in my application.
Thanks for helping me here. Smile
Swati
Re: Jar file not running on double click. [message #1598854 is a reply to message #1598806] Tue, 03 February 2015 02:46 Go to previous message
Did you inspect the jar file and is the fxml file there? Do you by
chance have a typo with upper/lower case which works in eclipse because
the windows filesystem is caseinsenstive?
Tom
On 03.02.15 08:01, Swati Sharma wrote:
> Hi Tom,
> Thanks
> File jarFile = new
> final FXMLLoader loader = new
> FXMLLoader(getClass().getResource("iAF_GUI.fxml"));
> stage.setTitle("IAF-Draft!"); stage.setScene(new
> Scene(root));
> stage.show();
> @Override
> Platform.exit();
> System.exit(0);
> return stage;
> Swati
Previous Topic:How to convert 0.8.1 Juno project to 1.2.0 Luna?
Next Topic:Unable to retrieve the bundle from ... at.bestsolution.e4.theme.css ...
Current Time: Sun Jul 20 20:23:20 EDT 2025
Powered by FUDForum. Page generated in 0.07683 seconds
