Home » Eclipse Projects » GEF » GEF right for block editor?
GEF right for block editor? [message #159579] Mon, 29 November 2004 12:08 Go to next message
Originally posted by: sathibault.yahoo.com
I need a block editor, and I'm wondering if GEF is the right way to go.
Looking at the examples, I notice that the routing is not that good (or
non-existant) and the display is not that nice. These may be problems
with the exmamples though, and not GEF. So, 1) Does GEF providing any
auto-routing (and specfically 90 degree only routing). 2) Is it easily
possible to improve the display with say thicker lines, anti-aliasing, and
maybe even rounded corners, for example?
The second problem I'm seeing is the eclipse platform itself seems to
support only one window per file. When working on a hierarchy of block
diagrams, one needs to be able to double-click on a block to open up its
sub-block in a second window and be able to alternate between the two
editing both the top block and sub-block. Is this possible? The only
solution I see is to used a tabbed widget in a single window, but I think
this would be really non-standard for a hierarchical block editor and not
well liked by the user.
Also, please let me know if there are any other frameworks that maybe I
should be considering as alternatives.
--Scott Thibault
Re: GEF right for block editor? [message #159603 is a reply to message #159579] Mon, 29 November 2004 12:46 Go to previous messageGo to next message
"Scott Thibault" <sathibault@yahoo.com> wrote in message
news:cofl1v$dud$1@www.eclipse.org...
> Hello,
See ShortestPathRouter. It is NOT orthogonal.
We use what SWT gives us.
You can do tabs or browser-style navigation.
> --Scott Thibault
Re: GEF right for block editor? [message #159811 is a reply to message #159603] Tue, 30 November 2004 12:01 Go to previous messageGo to next message
>> Hello,
>> I need a block editor, and I'm wondering if GEF is the right way to g=
o.
>> Looking at the examples, I notice that the routing is not that good (=
or
>> non-existant) and the display is not that nice. These may be problem=
s
>> with the exmamples though, and not GEF. So, 1) Does GEF providing an=
y
>> auto-routing (and specfically 90 degree only routing). 2) Is it easi=
ly
Isn=C2=B4t that what the ManhattanRouter is?
>> possible to improve the display with say thicker lines, anti-aliasing=
>> and
Check out this site:
http://www.holongate.org/holongate-2.0/gef/dev_docs.html
SCroll down to "Converting GEF applications"
>> The second problem I'm seeing is the eclipse platform itself seems to=
>> support only one window per file. When working on a hierarchy of blo=
ck
>> diagrams, one needs to be able to double-click on a block to open up =
its
>> sub-block in a second window and be able to alternate between the two=
>> editing both the top block and sub-block. Is this possible? The onl=
y
>> solution I see is to used a tabbed widget in a single window, but I =
>> think
>> this would be really non-standard for a hierarchical block editor and=
>> not
Check out the example extension for MultiPageEditor.
In the IBM Webtools Examples.The XSD-Editor is a navigator style gef =
editor,
while the xml editor is tabbed. (as is the plugin maifest editor for =
example)
Re: GEF right for block editor? [message #159871 is a reply to message #159811] Tue, 30 November 2004 15:59 Go to previous messageGo to next message
Isn
Re: GEF right for block editor? [message #159996 is a reply to message #159811] Wed, 01 December 2004 10:01 Go to previous message
Thanks for the answers. At this point, I'm thinking about trying to port
the Vergil editor from Ptolemy to a plug-in. It is a Swing application,
which I think is okay for eclipse, but can I use Swing with GEF?
My understanding is that it is already set up using a
viewer-controller-model architecture in swing. It's a very nice looking
editor. You can check it out at
http://ptolemy.eecs.berkeley.edu/ptolemyII/ptII4.0/ptII4.0.1 /doc/design/usingVergil/index.htm
--Scott
>>> Hello,
> IsnÂŽt that what the ManhattanRouter is?
>>> and
>>> think
>>> not
> editor,
> example)
Previous Topic:How to adapte the size of a figure to the size of its children ?
Next Topic:GEF and RCP - Where do they meet?
Current Time: Wed Jul 30 18:47:18 EDT 2025
Powered by FUDForum. Page generated in 0.04386 seconds
