Home » Eclipse Projects » GEF » Initializing the Grpahical Viewer leads to an exception
Initializing the Grpahical Viewer leads to an exception [message #159790] Tue, 30 November 2004 11:29 Go to next message
Originally posted by: rgitzel.wifo3.uni-mannheim.de
My GEF editor class has the following method which is similar to the one
found in the example programs:
protected void initializeGraphicalViewer()
initToolBar();
model = project.getModels()[0];
try
getGraphicalViewer().setContents(model);
} catch (Exception e)
System.out.println("Caught exception");
e.printStackTrace();
Surprisingly enough, I get the following output:
Caught exception
java.lang.IndexOutOfBoundsException: Figure.add(...) invalid index
at org.eclipse.draw2d.Figure.add(Figure.java:110)
at org.eclipse.draw2d.Figure.add(Figure.java:157)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addChild Visual(AbstractGraphicalEditPart.java:198)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:195)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:750)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:700)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
at
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:233)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:196)
at
org.eclipse.gef.editparts.ScalableRootEditPart.setContents(S calableRootEditPart.java:379)
at
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:581)
at
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:590)
at
omega.test.plugin.editors.OMEGAGraphicalEditor.initializeGra phicalViewer(OMEGAGraphicalEditor.java:67)
at
org.eclipse.gef.ui.parts.GraphicalEditor.createGraphicalView er(GraphicalEditor.java:138)
at
org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(G raphicalEditor.java:148)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:939)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
at org.eclipse.ui.internal.EditorStack.setSelection(EditorStack .java:196)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:10 20)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:290)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:121 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:59)
at
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:266)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:694)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:683)
at
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:779)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:582)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:570)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2244)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2177)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2169)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2156)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2151)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:299)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:96)
at
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:94)
at
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:111)
at
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:293)
at
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:624)
at
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:388)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:429)
at
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:427)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:635)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:731)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:211)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:206)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:238)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
When I do not catch the exception (which seem to occur only
*sometimes*(?)), the editor is not created, producing an entry in the
log. However, when I catch the exception, everything seems to work fine.
Yet, removing the offending command leads to an empty editor (as
expected). I have no idea what this is all about and any pointers would
be greatly appreciated.
Ralf
Re: Initializing the Grpahical Viewer leads to an exception [message #159928 is a reply to message #159790] Tue, 30 November 2004 21:07 Go to previous messageGo to next message
What does the getModelChildren() method of your EditPart (the one that's
experiencing the NPE) look like? You should be able to figure out the
problem if you step through the AbstractEditPart#refreshChildren() method.
"Ralf Gitzel" <rgitzel@wifo3.uni-mannheim.de> wrote in message
news:coi739$eh$1@www.eclipse.org...
> initToolBar();
> try
> Caught exception
> at
> at
5)
> at
java:750)
> at
> at
lEditPart.java:554)
> at
33)
> at
> at
6)
> at
art.java:379)
> at
Viewer.java:581)
> at
Viewer.java:590)
> at
> at
or.java:138)
> at
ava:148)
> at
:616)
> at
a:939)
> at
va:59)
> at
6)
> at
> at
779)
> at
..java:582)
> at
> at
va:2244)
> at
> at
> at
a:94)
> at
oup.java:111)
> at
oup.java:293)
> at
r.java:624)
> at
va:388)
> at
> at
:616)
> at
7)
> at
635)
> at
a:731)
> at
> at
> at
> at
java:335)
> at
> at
> Ralf
Re: Initializing the Grpahical Viewer leads to an exception [message #159938 is a reply to message #159928] Wed, 01 December 2004 02:28 Go to previous message
protected List getModelChildren()
IProjectElement temp = (IProjectElement) getModel();
List ret = new ArrayList();
IProjectSubElement[] elem = temp.getSubElements();
if (elem == null) return ret; // just in case...
for (int i=0; i < elem.length; i++)
ret.add(elem[i]);
return ret;
Some intensive debugging gave me the impression that there might be a
connection to the Edges in my graph. Seems like the
sourceConnections/targetCOnnections collections are null in
AbstractGraphicalEditPart but the addNotify() (?) method seems to assume
something else.
>>Hi,
>> initToolBar();
>> try
>>Caught exception
>>at
>>at
> 5)
>>at
> java:750)
>>at
>>at
> lEditPart.java:554)
>>at
> 33)
>>at
>>at
> 6)
>>at
> art.java:379)
>>at
> Viewer.java:581)
>>at
> Viewer.java:590)
>>at
>>at
> or.java:138)
>>at
> ava:148)
>>at
> :616)
>>at
> a:939)
>>at
> va:59)
>>at
> 6)
>>at
>>at
> 779)
>>at
> .java:582)
>>at
>>at
> va:2244)
>>at
>>at
>>at
> a:94)
>>at
> oup.java:111)
>>at
> oup.java:293)
>>at
> r.java:624)
>>at
> va:388)
>>at
>>at
> :616)
>>at
> 7)
>>at
> 635)
>>at
> a:731)
>>at
>>at
>>at
>>at
> java:335)
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>Thanks,
>> Ralf
Previous Topic:Linux Scroll Problem
Next Topic:About Palette Customization
Current Time: Wed Jul 30 20:15:28 EDT 2025
Powered by FUDForum. Page generated in 0.03592 seconds
