Base class retrieved value from eStaticClass() method [message #1597068] |
Sun, 01 February 2015 22:49  |
I'm dealing with E-core diagram where I have meta-class A generalized from meta-class B which in turn generalized from meta-class C. The retrieved baseclass value from "protected EClass eStaticClass(){}" generated method is the class A itself while in other cases using the same meta-model the retrieved value is class C.
The question is "is there something to do so that I control the retrieved baseclass value from eStaticClass method whether it should be the same class A dealt with or the generalized class C ? "
Thanks in advance.
Basheer
Re: Base class retrieved value from eStaticClass() method [message #1598099 is a reply to message #1597551] |
Mon, 02 February 2015 14:50  |
Basheer,
Comments below.
On 02.02.2015 12:26, Basheer Jasser wrote:
> Ed.,
> Comments below.
> In a generated model's implementation class, it should always be the
> EClass being implemented.
> As in this fraction of the diagram in Figure 1 which shows the generalization between different meta-classes , and the generated code in class A which is shown below
> public class AImpl extends BImpl implements A {
> * <!-- begin-user-doc -->
> * <!-- end-user-doc -->
> * @generated
> protected AImpl() {
> super();
> * @generated
> @Override
> protected EClass eStaticClass() {
> return MyPackage.Literals.A;
> } //AImpl
> So the natural behavior of eStaticClass() is to obtain class A as a returned value and it is not possible to return the generalized meta-class B or C ???
Yes, AImpl's eStaticClass must always return A's EClass instance.
> I'm facing some cases in the original project which is giving class C as the returned value ( I don't know why ). So maybe there is something to which is affecting eStaticClass() method behavior to return class C as retrieved value.
It seems impossible for a generated model, i.e., eStaticClass() ==
eClas() for instances of generated models. For a dynamic model that
extends a generated model, the two will be different.
> I'm not sure if you mean something special by 'baseclass'...
> The baseclass is the name of debugger variable which is representing the returned value of eStaticClass() method.
FUDForum. Page generated in 0.09084 seconds
