Home » Archived » BIRT » Can you help me? Myeclipse Birt Designer Error(Myeclipse Birt Designer Error)
icon2.gif  Can you help me? Myeclipse Birt Designer Error [message #1597042] Sun, 01 February 2015 22:24 Go to next message
The error is as follow:
I have a web project and I want add birt to it, so I selected the project and click Myeclipse-Project Capabilities-Add Report Capabilities, It seems to work good, but when I restart Myeclipse,the birt view designer didn't work, I screened the error as File Attachments, and copy the text description as this, thank you
at org.eclipse.birt.report.designer.ui.editors.ReportEditorProxy.init(ReportEditorProxy.java:139)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:828)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1459)
at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:972)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
  • Attachment: error.bmp
    (Size: 1.75MB, Downloaded 148 times)
Re: Can you help me? Myeclipse Birt Designer Error [message #1602846 is a reply to message #1597042] Thu, 05 February 2015 16:11 Go to previous message
Sounds like an issue with MyEclipse. Have you asked in their forums?
Previous Topic:Open design in RCP Designer from the command line
Next Topic:Can we use group by on combination of two rows?
Current Time: Thu Jul 31 03:54:50 EDT 2025
Powered by FUDForum. Page generated in 3.78876 seconds
