Home » Eclipse Projects » Eclipse Platform » Remote Debugging again
Remote Debugging again [message #159612] Thu, 20 November 2003 13:29 Go to next message
Originally posted by: hans.schwaebli.schwaebli.de
We have a remote computer in Switzerland and want to remote debug on it from
Germany.
In Eclipse I can enter the Host. What should I enter there? The IP address?
What about the login and password? How would such a Host address look like
in our case? What about the port? Does the firewall need to be configured
for the used port number?
Re: Remote Debugging again [message #159635 is a reply to message #159612] Thu, 20 November 2003 14:05 Go to previous messageGo to next message
Originally posted by: thomas_maeder.ch.ibm.com
Here's what you do:
1) log in to the computer in Switzerland (let's say it's called
figugegl.somecompany.ch)
2) Start your VM with -Xrunjdwp:....,address=8888, server=y, ...
3) In Germany, point the eclipse debugger at host
figugegl.somecompany.ch, port 8888 (i.e. create a new Remote Application
launch configuration).
4) connect.
Any firewall will have to be configured to allow IP connections on
whichever port you use.
Thomas
> Germany.
Re: Remote Debugging again [message #159642 is a reply to message #159635] Thu, 20 November 2003 14:14 Go to previous messageGo to next message
You write figugegl.somecompany.ch
But it is no web server. It is a EJB application server.
And what about the user name and password? How can I connect to a remote
machine without it?
"Thomas M
Re: Remote Debugging again [message #159713 is a reply to message #159642] Thu, 20 November 2003 15:09 Go to previous messageGo to next message
figugegl.somecompany.ch is a domain name, which translates into an IP
address. You could replace it with the IP address of the target host as
well.
> machine without it?
connect and login are different things. If the debugger is listening on
a given port, it can be accessed by anyone who knows the IP and port number.
> "Thomas Mäder" <thomas_maeder@ch.ibm.com> wrote in message
> news:bpj36b$s6t$1@eclipse.org...
>>Here's what you do:
>>4) connect.
>>Thomas
> from
>>>Germany.
> address?
> like
> configured
Re: Remote Debugging again [message #159719 is a reply to message #159713] Thu, 20 November 2003 15:31 Go to previous messageGo to next message
> > machine without it?
number.
Is this secure? What about hackers?
Re: Remote Debugging again [message #159807 is a reply to message #159719] Thu, 20 November 2003 17:15 Go to previous messageGo to next message
>>>machine without it?
> number.
What damage can somebody incur by connecting to the JPDA debugger? If
the debuggee process is not running with root privileges, I dont see
much danger. In any case, the hole is only open while the debuggee
process is running, and you are not connected to it.
christian
Re: Remote Debugging again [message #159900 is a reply to message #159807] Fri, 21 November 2003 01:10 Go to previous messageGo to next message
The hacker could terminate the remote vm! This would be very bad in a
production system!
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:bpje9g$98u$1@eclipse.org...
remote
> >>>machine without it?
> > number.
> christian
Re: Remote Debugging again [message #159951 is a reply to message #159900] Fri, 21 November 2003 04:32 Go to previous message
> production system!
you mean you would run the production system under a debugger??
> remote
>>>>>machine without it?
>>>number.
>>christian
Previous Topic:3.0M4 no longer running on Debian Sid
Next Topic:No clean refactoring
Current Time: Wed Sep 17 15:09:59 EDT 2025
Powered by FUDForum. Page generated in 0.07135 seconds
