Home » Archived » BIRT » Test execution Report - In BIRT
Test execution Report - In BIRT [message #159552] Tue, 09 May 2006 07:51
Originally posted by: krithivasan.gft.com
1.I have created a test suite ( Test , Test cases and Test Behavior).
2.After the manual test execution, I want to create test report from it.
3.The test report should be "Each case of the test behavior with its
description" , "Result from each test case ( pass or fail) " and the
"Comments " added to it during the execution.
Trials made : I have gone through the BIRT tutorials . I find only the
ways to connect to the data source, create a data set from the database
etc .
Help needed.
Thanks in advance.
Previous Topic:exception: save in error (why ?)
Next Topic:BIRT report with XML datasource: performance problem
Current Time: Fri Nov 07 12:33:53 EST 2025
Powered by FUDForum. Page generated in 0.03016 seconds
