Home » Language IDEs » Java Development Tools (JDT) » Source folder in Context Menu of JavaEditor
Source folder in Context Menu of JavaEditor [message #158408] Wed, 12 May 2004 09:19 Go to next message
Hi Eclipse Gurus
I want to add my own actions under the "Source" subfolder of the Java
Editor's context menu, however I don't see any obvious way to do that...
Any suggestions will be greatly appreciated
Thank you !
Re: Source folder in Context Menu of JavaEditor [message #158549 is a reply to message #158408] Thu, 13 May 2004 06:26 Go to previous messageGo to next message
This will work with the most recent integration builds:
<!-- define the foo command -->
<!-- the command can then be referenced by various UI elements (actions,
keybindings, toolbar etc.) -->
<extension
point="org.eclipse.ui.commands">
<command
name="FooCommand"
description="Executes Foo"
category="org.eclipse.jdt.ui.category.source"
id="com.example.commands.foo">
</command>
</extension>
<!-- register an action for foo in the source menu -->
<!-- note that this will only add an entry to the context menu, not the
main menu -->
<extension
point="org.eclipse.ui.popupMenus">
<viewerContribution
targetID="#CompilationUnitEditorContext">
<action
definitionId="com.example.commands.foo"
label="Foo"
menubarPath="org.eclipse.jdt.ui.source.menu/additions"
class="com.example.actions.source.FooAction"
id="com.example.actions.source.foo">
</action>
</viewerContribution>
</extension>
-tom
Leho Nigul wrote:
> Hi Eclipse Gurus
> Thank you !
Re: Source folder in Context Menu of JavaEditor [message #158606 is a reply to message #158549] Thu, 13 May 2004 12:33 Go to previous messageGo to next message
Hi Tom
Thank you for your suggestion.
I tried it, but still got
"Invalid Menu Extension (Path is invalid): com.example.actions.source.foo"
Any other suggestions that I try?
Thank you !
"Tom Eicher" <eclipse@tom.eicher.name> wrote in message
news:c7vi38$94s$1@eclipse.org...
> <extension
> <command
> name="FooCommand"
> </command>
> </extension>
> main menu -->
> <extension
> <viewerContribution
> <action
> label="Foo"
> </action>
> </extension>
> -tom
> Leho Nigul wrote:
> > Hi Eclipse Gurus
> > Thank you !
Re: Source folder in Context Menu of JavaEditor [message #158622 is a reply to message #158606] Thu, 13 May 2004 12:47 Go to previous messageGo to next message
For this to work, you need I20040513_0800 - are you sure you have that?
-tom
Leho Nigul wrote:
> Hi Tom
> Thank you !
>><extension
>> <command
>> name="FooCommand"
>> </command>
>></extension>
>>main menu -->
>><extension
>> <viewerContribution
>> <action
>> label="Foo"
>> </action>
>></extension>
>>-tom
>>Leho Nigul wrote:
>>> Hi Eclipse Gurus
>>>Thank you !
Re: Source folder in Context Menu of JavaEditor [message #159346 is a reply to message #158622] Tue, 18 May 2004 16:55 Go to previous message
Hi Tom
You were right, I was on the older driver. It works on the latest one.
Thank you!
news:c808d6$6sj$1@eclipse.org...
> -tom
> Leho Nigul wrote:
> > Hi Tom
> > Thank you !
> >><extension
> >> <command
> >> name="FooCommand"
> >> </command>
> >></extension>
> >>main menu -->
> >><extension
> >> <viewerContribution
> >> <action
> >> label="Foo"
> >> </action>
> >></extension>
> >>-tom
> >>Leho Nigul wrote:
> >>> Hi Eclipse Gurus
that...
> >>>Thank you !
Previous Topic:File Menu: resource history
Next Topic:New Formatter - Assignment statments
Current Time: Fri Oct 31 01:18:39 EDT 2025
Powered by FUDForum. Page generated in 0.04110 seconds
