Home » Eclipse Projects » Sirius » Adding elements dynamically
Adding elements dynamically [message #1591297] Thu, 29 January 2015 07:45 Go to next message
I recently started using Sirius and I must say that it has been a real pleasure. Sirius has met most of my needs almost straight out of the box without much of a learning curve. As I used Sirius, I found that I could do more than I originally anticipated.
It is in one of those exercises I came to this problem. I want to build a diagram based on Sirius, where some of the nodes/containers.edges come from other plugins.
Think something like Visio (a crude analogy) where we can plugin stencils and diagram files and mix these nodes.
I want to provide a basic model of elements in my plugins and later contribute additional elements with other plugins. Is this doable?
In the diagram extension, it looks as if I need to create an additional layer to add elements. Couldn't I add elements to the default layer?
Deepu roy
Re: Adding elements dynamically [message #1593089 is a reply to message #1591297] Fri, 30 January 2015 07:07 Go to previous messageGo to next message
Le 29/01/2015 13:45, Deepu Roy a écrit :
> could do more than I originally anticipated. It is in one of those
Yes, it is possible rightly with diagram extension.
In
Not to the default layer, but there are options an additional layer to
consider it as :
* not optional: The end-user can not deactivate this layer
* active by default
> Deepu roy
Laurent - Obeo
Need professional services for Sirius?
Re: Adding elements dynamically [message #1598051 is a reply to message #1593089] Mon, 02 February 2015 14:05 Go to previous message
Laurent,
Thanks for the help. I've been able to get my diagram to work.
Deepu Roy
Previous Topic:Sub-containers on diagram inside same container
Next Topic:[Solved] Distinguish child nodes from imported nodes on diagram
Current Time: Fri Jul 25 17:32:52 EDT 2025
Powered by FUDForum. Page generated in 0.06703 seconds
