Home » Language IDEs » Java Development Tools (JDT) » Variable creation
Variable creation [message #159281] Tue, 18 May 2004 10:15 Go to next message
Originally posted by: rndzank.comcast.net.not_this.net
In IDEA, there are two features related to variable creation that I miss in
Eclipse. You can type this in IDEA:
myarray.length|
// note the cursor at the end doesn't select the whole expression
// and there is no semicolon
.... then hit the shortcut for 'Introduce Variable' and you get
int length = myarray.length;
// note also the added semicolon
In Eclipse, I have to have syntactically correct code in order to
introduce local variable. In this case, you have to use the expression somewhere.
Are there any known plans to enable this kind of usage in Eclipse?
r.
Re: Variable creation [message #159289 is a reply to message #159281] Tue, 18 May 2004 10:23 Go to previous messageGo to next message
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Richard,
If myarray.length instead were a method invocation, Eclipse's Quick
Assist would suggest to assign the return value to a local variable
(provided you add the semicolon yourself first). However, since
variables by themselves are not syntactically correct, this is not
suggested.
I agree that it would be nice to have this kind of assistance. You might
want to add a bug report.
Jesper
> in Eclipse. You can type this in IDEA:
> myarray.length|
> somewhere.
> Thanks
> r.
Re: Variable creation [message #159297 is a reply to message #159289] Tue, 18 May 2004 10:46 Go to previous message
Done, as https://bugs.eclipse.org/bugs/show_bug.cgi?id=62655
r.
Jesper Kamstrup Linnet wrote:
> Hi Richard,
> suggested.
> Best regards,
> Jesper
>> miss in Eclipse. You can type this in IDEA:
>> myarray.length|
>> somewhere.
>> Thanks
>> r.
Previous Topic:Build in Progress...
Next Topic:java project build state
Current Time: Tue Sep 16 20:13:00 EDT 2025
Powered by FUDForum. Page generated in 0.04553 seconds
