Home » Modeling » GMF (Graphical Modeling Framework) » Attribute Symbols
Attribute Symbols [message #158782] Thu, 08 November 2007 03:45 Go to next message
Originally posted by: 14.08.99.gmx.de
is it possible to change the symbol of attributes?
E.g. I have a red cricle to represent a node in my ToolBar (this is
ok!). This node has 2 Attributes (Labels). When I draw such a node, both
of the Attributes have a red circle on the left... How do I change or
delete this symbol?
Greets,
Guido
Re: Attribute Symbols [message #158895 is a reply to message #158782] Thu, 08 November 2007 06:54 Go to previous messageGo to next message
Hi Guido,
If I understood you correctly, you should set the elementIcon property
of DiagramLabel to false in your gmfmap model for the labels where the
icons are not needed.
Boris
Guido Schwab wrote:
> delete this symbol?
> Greets,
> Guido
Re: Attribute Symbols [message #158940 is a reply to message #158895] Thu, 08 November 2007 07:53 Go to previous messageGo to next message
Hi Boris,
Thank you for the answer. It works, the symbol does not appear anymore.
Is there a possibility to display another symbol (e.g. "-" or "+")?
Greets,
Guido
Boris Blajer schrieb:
> Hi Guido,
> Best regards,
> Boris
> Guido Schwab wrote:
>> Hi,
>> both of the Attributes have a red circle on the left... How do I
>> change or delete this symbol?
>> Greets,
>> Guido
Re: Attribute Symbols [message #158977 is a reply to message #158940] Thu, 08 November 2007 08:30 Go to previous messageGo to next message
Hi Guido,
Find the generated XyzEditPart.getLabelIcon() method and modify its body
to return some other icon (preferably from some image registry). Do not
forget to mark the method as @generated NOT.
Boris
Guido Schwab wrote:
> Hi Boris,
> Greets,
> Guido
>> Hi Guido,
>> Best regards,
>> Boris
>> Guido Schwab wrote:
>>> Hi,
>>> Greets,
>>> Guido
Re: Attribute Symbols [message #159143 is a reply to message #158977] Fri, 09 November 2007 02:34 Go to previous messageGo to next message
Thank you...
> Hi Guido,
> Best regards,
> Boris
> Guido Schwab wrote:
>> Hi Boris,
>> anymore. Is there a possibility to display another symbol (e.g. "-" or
>> Greets,
>> Guido
>>> Hi Guido,
>>> property of DiagramLabel to false in your gmfmap model for the labels
>>> where the icons are not needed.
>>> Best regards,
>>> Boris
>>> Guido Schwab wrote:
>>>> Hi,
>>>> Greets,
>>>> Guido
Re: Attribute Symbols [message #159480 is a reply to message #159143] Sat, 10 November 2007 15:36 Go to previous messageGo to next message
Originally posted by: Sam.sam.org
your graphical editor consist of several projects. in your XXX.edit project
there is an /icons/full/obj16 folder. all images come from here. you might
simply replace your desired image. you don't even have to regenerate.
regards
Matthias
"Guido Schwab" <14.08.99@gmx.de> schrieb im Newsbeitrag
news:fh12ht$fmp$1@build.eclipse.org...
> Thank you...
>> Hi Guido,
>> Best regards,
>> Boris
>> Guido Schwab wrote:
>>> Hi Boris,
>>> Greets,
>>> Guido
>>>> Hi Guido,
>>>> Best regards,
>>>> Boris
>>>> Guido Schwab wrote:
>>>>> Hi,
>>>>> Greets,
>>>>> Guido
Re: Attribute Symbols [message #159556 is a reply to message #159480] Mon, 12 November 2007 02:54 Go to previous message
Hi Sam/Matthias,
changing the icon in the obj16 Folder changes ALL icons: tool-palette,
graphical symbol and attributes. I only wanted to change the icon for
attributes.
Greets,
Guido
Sam schrieb:
> regards
> Matthias
>> Thank you...
>>> Hi Guido,
>>> Best regards,
>>> Boris
>>> Guido Schwab wrote:
>>>> Hi Boris,
>>>> Greets,
>>>> Guido
>>>>> Hi Guido,
>>>>> Best regards,
>>>>> Boris
>>>>> Guido Schwab wrote:
>>>>>> Hi,
>>>>>> Greets,
>>>>>> Guido
Previous Topic:Memory Leak... Urgent... Please Help
Next Topic:props "types in selection" & more
Current Time: Fri Sep 19 14:01:27 EDT 2025
Powered by FUDForum. Page generated in 0.05288 seconds
