Added new figures to the diagram. [message #158529] |
Thu, 18 November 2004 14:21  |
Originally posted by: jsk_lam.hotmail.com
I have a model which contains a hierarchy structure of nodes. Everything
works fine if I create
all the node objects in the method
AbstractEditorPage#createGraphicalViewer() and the GEF
EditPartFactory#createEditorPart() will eventually be invoked to create the
edit part for all the
nodes.
But the diagram is so complex, I would like to only create the first level
of nodes and let the
user click on a specific node and expand it to show all the children nodes.
In this case, I do
not create all the nodes in the AbstractEditorPage#createGraphicalViewer(),
and only add
those children nodes to the diagram when the parent node is expanded.
I only call GraphicalViewer.setContents(diagram) in
when the editor page is first loaded. How do I added those new children
nodes to my diagram
and invoke the EditPartFactory#createEditorPart() to create the
editparts/figures for those new
nodes? By the way, I am not using any palette at all.
slam
Re: Added new figures to the diagram. [message #159134 is a reply to message #158529] |
Mon, 22 November 2004 16:44  |
getModelChildren() should return an empty list when the node is collapsed,
and the actual children when the node is expanded. You'll have to invoke
refreshChildren() when a node is collapsed/expanded.
"slam" <jsk_lam@hotmail.com> wrote in message
news:cnisov$r5m$1@www.eclipse.org...
the
> nodes.
nodes.
> In this case, I do
> and only add
> nodes to my diagram
> Thanks
> slam
FUDForum. Page generated in 0.52968 seconds
