OSLCClient getEntity function [message #1587784] |
Tue, 27 January 2015 10:03  |
I have just one basic question:
Is there a way to see the declaration of response.getEntity() function in client project? I just want to debug but I can not go in to that function to see how it works. I was wondering if this is something happens to me may be because of missing files/environment or everyone have same difficulty.
Here is the code how I use getEntity() function to give you an idea:
OslcClient client = new OslcClient();
response = client.getResource(resourceURI, OSLCConstants.CT_RDF);
EntityB resource = response.getEntity(EntityB.class);
Thanks in advance
Re: OSLCClient getEntity function [message #1589574 is a reply to message #1587995] |
Wed, 28 January 2015 09:28  |
Hi Samuel,
Thank you very much for your reply. I am using client from ToolAAdaptor to receive entity from ToolBAdapter. respond looks fine actually, but as I mentioned before after calling respond.getEntity() it becomes null.
Can that be because of "ToolBAdaptor" initial in RDF? Since the call is from ToolAAdaptor maybe this needs to be ToolAadapter? Or am I making thing complicated?
I printed out response and this is the result I receive:
<rdf:RDF
xmlns:rdf="somelink/1999/02/22-rdf-syntax-ns#"
xmlns:dcterms="somelink/dc/terms/"
xmlns:oslc_data="somelink/ns/servicemanagement/1.0/"
xmlns:oslc="somelink/ns/core#"
xmlns:rdfs="somelink/2000/01/rdf-schema#"
xmlns:ms="somelink/ToolBAdaptor"
xmlns:j.0="somelink/" >
<rdf:Description rdf:about="somelink:8282/ToolBAdaptor/services/serviceProviders/1/entitys/4">
<j.0:ToolBAdaptorEntityState>C</j.0:ToolBAdaptorEntityState>
<j.0:ToolBAdaptorEntityDescription>Description4</j.0:ToolBAdaptorEntityDescription>
<j.0:ToolBAdaptorEntityTitle>Title4</j.0:ToolBAdaptorEntityTitle>
<rdf:type rdf:resource="somelink/ToolBAdaptorentity"/>
</rdf:Description>
</rdf:RDF>
EntityB.java is:
@OslcNamespace(ToolBAdaptorConstants.TOOLBADAPTOR_NAMSPACE)
@OslcName(ToolBAdaptorConstants.ENTITY)
@OslcResourceShape(title = "Entity Resource Shape", describes = ToolBAdaptorConstants.TYPE_ENTITY)
public class EntityB
extends AbstractResource
public String EntityTitle;
public String EntityDescription;
public String EntityState;
public EntityB()
throws URISyntaxException
super();
// Start of user code constructor1
// End of user code
public EntityB(final URI about)
super(about);
// Start of user code constructor2
// End of user code
public EntityB(final String serviceProviderId, final String entityId)
this (constructURI(serviceProviderId, entityId));
// Start of user code constructor3
// End of user code
public static URI constructURI(final String serviceProviderId, final String entityId)
String basePath = ServletListener.getServicesBase();
Map<String, Object> pathParameters = new HashMap<String, Object>();
pathParameters.put("serviceProviderId", serviceProviderId);
pathParameters.put("entityId", entityId);
String instanceURI = "serviceProviders/{serviceProviderId}/entitys/{entityId}";
final UriBuilder builder = UriBuilder.fromUri(basePath);
return builder.path(instanceURI).buildFromMap(pathParameters);
public static Link constructLink(final String serviceProviderId, final String entityId , final String label)
return new Link(constructURI(serviceProviderId, entityId), label);
public static Link constructLink(final String serviceProviderId, final String entityId)
return new Link(constructURI(serviceProviderId, entityId));
public String toString()
return toString(false);
public String toString(boolean asLocalResource)
String result = "";
// Start of user code toString_init
// End of user code
if (asLocalResource) {
result = result + "{a Local Entity Resource} - update Entity.toString() to present resource as desired.";
// Start of user code toString_bodyForLocalResource
// End of user code
else {
result = getAbout().toString();
// Start of user code toString_finalize
// End of user code
return result;
public String toHtml()
return toHtml(false);
public String toHtml(boolean asLocalResource)
String result = "";
// Start of user code toHtml_init
// End of user code
result = toString(true);
// Start of user code toHtml_bodyForLocalResource
// End of user code
else {
result = "<a href=\"" + getAbout() + "\">" + toString() + "</a>";
// Start of user code toHtml_finalize
// End of user code
return result;
public String toHtmlUpdate()
return toHtmlUpdate(false);
public String toHtmlUpdate(boolean asLocalResource)
String result = "";
// End of user code
// End of user code
else {
result = "<a href=\"" + getAbout() + "/update"+"\">" + toString() + "/update</a>";
// End of user code
return result;
@OslcName("EntityTitle")
@OslcPropertyDefinition(ToolBAdaptorConstants.TOOLBADAPTOR_NAMSPACE + "EntityTitle")
@OslcDescription("Entity Can be Anything... (e.g., block , Bug)")
@OslcOccurs(Occurs.ExactlyOne)
@OslcValueType(ValueType.String)
@OslcReadOnly(false)
@OslcTitle("EntityTitle")
public String getEntityTitle()
return EntityTitle;
@OslcName("EntityDescription")
@OslcPropertyDefinition(ToolBAdaptorConstants.TOOLBADAPTOR_NAMSPACE + "EntityDescription")
@OslcDescription("Description")
@OslcTitle("EntityDescription")
public String getEntityDescription()
return EntityDescription;
@OslcName("EntityState")
@OslcPropertyDefinition(ToolBAdaptorConstants.TOOLBADAPTOR_NAMSPACE + "EntityState")
@OslcDescription("Status of the entity")
@OslcTitle("EntityState")
public String getEntityState()
return EntityState;
public void setEntityTitle(final String EntityTitle )
this.EntityTitle = EntityTitle;
public void setEntityDescription(final String EntityDescription )
this.EntityDescription = EntityDescription;
public void setEntityState(final String EntityState )
this.EntityState = EntityState;
static public String EntityTitleToHtmlForCreation (final HttpServletRequest httpServletRequest, final String serviceProviderId)
String s = "";
// Start of user code EntityTitleasHtmlForCreation_init
// End of user code
s = s + "<label for=\"EntityTitle\">EntityTitle: </LABEL>";
// Start of user code EntityTitleasHtmlForCreation_mid
// End of user code
s= s + "<input name=\"EntityTitle\" type=\"text\" style=\"width: 400px\" id=\"EntityTitle\" >";
// Start of user code EntityTitleasHtmlForCreation_finalize
// End of user code
return s;
static public String EntityDescriptionToHtmlForCreation (final HttpServletRequest httpServletRequest, final String serviceProviderId)
String s = "";
// Start of user code EntityDescriptionasHtmlForCreation_init
// End of user code
s = s + "<label for=\"EntityDescription\">EntityDescription: </LABEL>";
// Start of user code EntityDescriptionasHtmlForCreation_mid
// End of user code
s= s + "<input name=\"EntityDescription\" type=\"text\" style=\"width: 400px\" id=\"EntityDescription\" >";
// Start of user code EntityDescriptionasHtmlForCreation_finalize
// End of user code
return s;
static public String EntityStateToHtmlForCreation (final HttpServletRequest httpServletRequest, final String serviceProviderId)
String s = "";
// Start of user code EntityStateasHtmlForCreation_init
// End of user code
s = s + "<label for=\"EntityState\">EntityState: </LABEL>";
// Start of user code EntityStateasHtmlForCreation_mid
// End of user code
s= s + "<input name=\"EntityState\" type=\"text\" style=\"width: 400px\" id=\"EntityState\" >";
// Start of user code EntityStateasHtmlForCreation_finalize
// End of user code
return s;
static public String EntityTitleToHtmlForUpdate (EntityB entity)
String s = "";
// End of user code
// End of user code
s= s + "<input name=\"EntityTitle\" type=\"text\" style=\"width: 400px\" id=\"EntityName\""+ "value=\""+ entity.EntityTitle +"\" >";
// End of user code
return s;
static public String EntityDescriptionToHtmlForUpdate (EntityB entity)
String s = "";
// End of user code
// End of user code
s= s + "<input name=\"EntityDescription\" type=\"text\" style=\"width: 400px\" id=\"EntityDescription\""+ "value=\""+ entity.EntityDescription +"\" >";
// End of user code
return s;
static public String EntityStateToHtmlForUpdate (EntityB entity)
String s = "";
// End of user code
// End of user code
s= s + "<input name=\"EntityState\" type=\"text\" style=\"width: 400px\" id=\"EntityState\""+ "value=\""+ entity.EntityState +"\" >";
// End of user code
return s;
public String EntityTitleToHtml()
String s = "";
// Start of user code EntityTitletoHtml_init
// End of user code
s = s + "<label for=\"EntityTitle\"><strong>EntityTitle</strong>: </LABEL>";
// Start of user code EntityTitletoHtml_mid
// End of user code
try {
if (EntityTitle == null) {
s= s + "<em>null</em>";
else {
s= s + EntityTitle.toString();
} catch (Exception e) {
e.printStackTrace();
// Start of user code EntityTitletoHtml_finalize
// End of user code
return s;
public String EntityDescriptionToHtml()
String s = "";
// Start of user code EntityDescriptiontoHtml_init
// End of user code
s = s + "<label for=\"EntityDescription\"><strong>EntityDescription</strong>: </LABEL>";
// Start of user code EntityDescriptiontoHtml_mid
// End of user code
try {
if (EntityDescription == null) {
else {
s= s + EntityDescription.toString();
// Start of user code EntityDescriptiontoHtml_finalize
// End of user code
return s;
public String EntityStateToHtml()
String s = "";
// Start of user code EntityStatetoHtml_init
// End of user code
s = s + "<label for=\"EntityState\"><strong>EntityState</strong>: </LABEL>";
// Start of user code EntityStatetoHtml_mid
// End of user code
try {
if (EntityState == null) {
else {
s= s + EntityState.toString();
// Start of user code EntityStatetoHtml_finalize
// End of user code
return s;
FUDForum. Page generated in 0.04440 seconds
