Re: pdf generation w/ parameters [message #161240 is a reply to message #159510] |
Mon, 15 May 2006 20:33  |
Hi Jason,
Thanks for your suggestions. I am happy to report that this was not a
BIRT issue at all, our application does some post processing on requests
that was causing this issue.
Sorry for the unnecessary traffic on the board.
-Brian
Jason Weathersby wrote:
> Brian,
> Can you try a couple of things?
> 1 - try adding a parameter and displaying it in a data element.
> ie add the data element and set its value to params["myparameter"].
> Do this without changing the locale.
> 2 - Can you try 2.0.1?
> Thanks
> Jason
> "Brian Kallay" <brian.kallay@bricsnet.com> wrote in message
> news:e3gm6c$4fd$1@utils.eclipse.org...
>>Hi,
>>I am using BIRT 2.0.0 and experiencing the following issue:
>>I have made what I believe are the necessary modifications for the PDF
>>emitter and I am able to get a simple report to render in Acrobat as PDF.
>>The problem is that when I try to render a report that depends on
>>parameters (being passed in on the URL) I get a blank page in the Acrobat
>>viewer. Furthermore if I take the working simple example from above and
>>add a parameter to the URL I get a blank page.
>>Just to be clear:
>> http://localhost/run?__report=table.rptdesign&__format=p df
>>-this successfully generates the PDF
>> http://localhost/run?__report=table.rptdesign&__format=p df&__locale=en_US
>>-this opens acrobat with a blank page, no errors in the logs
>>Any suggestions?
>>thanks,
>>Brian
FUDForum. Page generated in 0.28365 seconds
