Home » Archived » Jubula » Jubula 8.1
Jubula 8.1 [message #1587735] Tue, 27 January 2015 09:30 Go to next message
hi there,
i saw Jubula 8.1 was released today. i read the blog entry from Alex now but cant find the release notes she mentioned. Can anybody tell me where i can find them? I would like to evaluate if it would be worthwhile to update from 8.0 for me.
Sincerely
Dominik
Re: Jubula 8.1 [message #1587769 is a reply to message #1587735] Tue, 27 January 2015 09:55 Go to previous messageGo to next message
Hi Dominik,
I think you were just a bit faster than I was: they're online now under the documentation section in the portal Smile If you can't find them, let me know.
Alex
Re: Jubula 8.1 [message #1587785 is a reply to message #1587769] Tue, 27 January 2015 10:04 Go to previous messageGo to next message
hi Alex,
thanks 4 ur answer. i found it there right now. i wasn't looking at the time the blog entry was posted Razz
Thank u very much
Re: Jubula 8.1 [message #1589004 is a reply to message #1587785] Wed, 28 January 2015 02:18 Go to previous messageGo to next message
hi alex,
is it right that there wpuld be another release in about a half a year? (https://projects.eclipse.org/projects/technology.jubula). If there is an update then i am not sure if i should udpate now and again in half a year. Since i have to make a new database each version, it's a little comlicated to make an update in our company. Would there be any problems with the migration of my my Project when i jump this version?
sincerely
Dominik
Re: Jubula 8.1 [message #1590878 is a reply to message #1589004] Thu, 29 January 2015 02:27 Go to previous message
Hi Dominik,
We are planning on bringing out standalone releases in around 4-week cycles to keep everyone up to date with new developments. Mars is also coming out in June. We do indeed recommend that you create a new scheme per version so that you can keep the old one while migrating. We don't usually test larger migrations (from much older projects to newer ones) so although it has worked in the past, I can't 100% guarantee that it will be the case.
Hope this information helps a little!
Alex
Previous Topic:is it possible to check where a View is
Next Topic:Object Mapping Not Working
Current Time: Sat Jul 19 02:41:48 EDT 2025
Powered by FUDForum. Page generated in 0.23282 seconds
