Home » Language IDEs » ServerTools (WTP) » Eclipse 3.2M4, WTP 1.5M4, JBoss 4 problem
Eclipse 3.2M4, WTP 1.5M4, JBoss 4 problem [message #158749] |
Wed, 01 February 2006 18:44  |
Originally posted by: jfallows.txesystems.com
Hi there,
I have downloaded and installed a pristine Eclipse 3.2M4, as well as all
the other dependencies listed for WebTools 1.5M4.
http://download.eclipse.org/webtools/downloads/drops/S-1.5M4 -200601131852/
After some research online, I discovered Wolfgang's homemade JBoss 4
server definitions for WebTools 1.0, which seem to work with WebTools
1.5M4 - thanks Wolfgang!
When running JSP page using Debug As|Debug on Server, JBoss 4
automatically starts up as desired, then the JSP page is requested and
displayed in an embedded browser inside Eclipse IDE.
Unfortunately, I get the following stack trace displayed in the browser
window when the JSP runtime tries to compile the JSP page to a class file.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP
org.apache.jasper.compiler.DefaultErrorHandler.javacError(De faultErrorHandler.java:97)
org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorD ispatcher.java:346)
org.apache.jasper.compiler.Compiler.generateClass(Compiler.j ava:414)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:47 2)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:45 1)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:43 9)
org.apache.jasper.JspCompilationContext.compile(JspCompilati onContext.java:511)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:295)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:292)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :236)
javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:75)
root cause
Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
org.apache.tools.ant.taskdefs.compilers.CompilerAdapterFacto ry.getCompiler(CompilerAdapterFactory.java:105)
org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:929)
org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:758)
org.apache.jasper.compiler.Compiler.generateClass(Compiler.j ava:382)
However, my JBoss server definition's "JRE" is pointing to JDK 1.5.0_03
so it should be picking up the JDK-based JAVA_HOME that includes tools.jar.
I even tried manually setting the JAVA_HOME environment variable in the
"Environment" tab of the JBoss 4.0.x Debug Configuration.
Does anyone know how I can use WTP on Eclipse 3.2M4 with JBoss 4?
Kind Regards,
John Fallows.
Re: Eclipse 3.2M4, WTP 1.5M4, JBoss 4 problem [message #158777 is a reply to message #158749] |
Thu, 02 February 2006 03:57   |
Originally posted by: n.metchev.teamphone.com
by default when creating a JDK runtime eclipse doesn't pick up the tools.jar
that is located in your JDK installation directory under /libs.
You need to edit your JDK Runtime and add the tools.jar to it.
"John R. Fallows" <jfallows@txesystems.com> wrote in message
news:drrh5b$hg8$1@utils.eclipse.org...
> Hi there,
> exception
> root cause
> However, my JBoss server definition's "JRE" is pointing to JDK 1.5.0_03 so
> Kind Regards,
> John Fallows.
Re: Eclipse 3.2M4, WTP 1.5M4, JBoss 4 problem [message #158800 is a reply to message #158777] |
Thu, 02 February 2006 13:43   |
Thanks Nicolay, that worked!
Btw, where should I file this as a bug/enhancement so that others do not
run into the same problem?
Kind Regards,
John Fallows.
>> Hi there,
>> exception
>> root cause
>> Kind Regards,
>> John Fallows.
Re: Eclipse 3.2M4, WTP 1.5M4, JBoss 4 problem [message #158807 is a reply to message #158800] |
Thu, 02 February 2006 14:23  |
Filed bug 126239 "Installed JRE definition misses tools.jar when
pointing to JDK".
https://bugs.eclipse.org/bugs/show_bug.cgi?id=126239
Hopefully this will prevent others from spending many frustrating hours
trying to figure out what went wrong. ;)
Kind Regards,
John Fallows.
> Kind Regards,
> John Fallows.
>> tools.jar that is located in your JDK installation directory under /libs.
>>> Hi there,
>>> all the other dependencies listed for WebTools 1.5M4.
>>> and displayed in an embedded browser inside Eclipse IDE.
>>> browser window when the JSP runtime tries to compile the JSP page to
>>> a class file.
>>> exception
>>> root cause
>>> 1.5.0_03 so it should be picking up the JDK-based JAVA_HOME that
>>> includes tools.jar.
>>> the "Environment" tab of the JBoss 4.0.x Debug Configuration.
>>> Kind Regards,
>>> John Fallows.
Current Time: Wed Oct 08 09:22:51 EDT 2025
Powered by FUDForum. Page generated in 0.05065 seconds
