| Problem with Cheetah04 [message #158598] |
Thu, 13 May 2004 12:31  |
Originally posted by: Lynn.Orrell.wiltel.com
All -
I just downloaded the 8:00 AM integration build I20040513 and installed
Cheetah04. Is there anything else I need to do to get preliminary JDK1.5
support? When I attempt to open a source file I get the following error
message: An error has occurred when creating this editor.
Can anyone please list the steps required to get this working?
Any help would be greatly appreciated.
Thanks!
Lynn
| Re: Problem with Cheetah04 [message #158639 is a reply to message #158598] |
Thu, 13 May 2004 12:57   |
Some additional infomation. The following stack traces were in the log
file.
!SESSION May 13, 2004
11:42:49.781 ---------------------------------------------
eclipse.buildId=I200405130010
java.version=1.4.2_03
!ENTRY org.eclipse.jdt.ui 4 10001 May 13, 2004 11:42:49.781
!MESSAGE preference option missing:
org.eclipse.jdt.core.compiler.problem.unnecessaryElse
(org.eclipse.jdt.internal.ui.preferences.CompilerConfigurati onBlock)
!ENTRY org.eclipse.compare 4 1 May 13, 2004 11:45:10.78
!MESSAGE content type 'org.eclipse.jdt.core.javaSource' not found
!MESSAGE target id attribute 'contentViewerId' missing
!ENTRY org.eclipse.core.runtime 4 2 May 13, 2004 11:45:42.296
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/jdt/internal/codeassist/IExtendedCompletionReque stor
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.define
Class(DefaultClassLoader.java:292)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClass
Loader.java:207)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findCl
assImpl(DefaultClassLoader.java:281)
at
ass(DefaultClassLoader.java:172)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(A
bstractClassLoader.java:220)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
assLoader.java:59)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
oader.java:368)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:399)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at
at
Loader.java:207)
at
at
at
at
assLoader.java:59)
at
oader.java:368)
at
..java:399)
at
at
org.eclipse.jdt.ui.text.JavaSourceViewerConfiguration.getCon tentAssistant(Ja
vaSourceViewerConfiguration.java:380)
at
org.eclipse.jface.text.source.SourceViewer.configure(SourceV iewer.java:315)
at
org.eclipse.jdt.internal.ui.javaeditor.JavaSourceViewer.conf igure(JavaSource
Viewer.java:172)
at
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor $AdaptedSourceVi
ewer.configure(CompilationUnitEditor.java:287)
at
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextE
ditor.java:2221)
at
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEdito
r.java:53)
at
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(Abst
ractDecoratedTextEditor.java:279)
at
org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.createPart Control(JavaEdit
or.java:3264)
at
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .createPartContr
ol(CompilationUnitEditor.java:1594)
at org.eclipse.ui.internal.PartPane$1.run(PartPane.java:93)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:607)
at org.eclipse.core.runtime.Platform.run(Platform.java:668)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:89)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :150)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.jav
a:710)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:692)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:152)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:100 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.ja
va:56)
at
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:25
7)
at org.eclipse.ui.internal.EditorManager$2.run(EditorManager.ja va:550)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:539
at
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:
635)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:438)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:426)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2137
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2080)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2067)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2062)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:301)
at
org.eclipse.jdt.internal.ui.wizards.NewElementWizard$1.run(N ewElementWizard.
java:63)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2702)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2394)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1353)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1324)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:243)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:90)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:298)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:249)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:126)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:269)
at org.eclipse.core.launcher.Main.run(Main.java:722)
at org.eclipse.core.launcher.Main.main(Main.java:706)
!ENTRY org.eclipse.core.runtime 4 2 May 13, 2004 11:45:42.312
!STACK 0
java.lang.ClassCastException
at
org.eclipse.jdt.internal.ui.javaeditor.ASTProvider.activeJav aEditorChanged(A
STProvider.java:216)
at
org.eclipse.jdt.internal.ui.javaeditor.ASTProvider.access$0( ASTProvider.java
:211)
at
org.eclipse.jdt.internal.ui.javaeditor.ASTProvider$Activatio nListener.partOp
ened(ASTProvider.java:100)
at
org.eclipse.ui.internal.PartListenerList2$5.run(PartListener List2.java:101)
at
:607)
at
org.eclipse.ui.internal.PartListenerList2.firePartOpened(Par tListenerList2.j
ava:99)
at
org.eclipse.ui.internal.WWinPartService$1.partOpened(WWinPar tService.java:62
at
at
:607)
at
ava:99)
at
org.eclipse.ui.internal.WorkbenchPage.firePartOpened(Workben chPage.java:1385
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:119)
at
a:710)
at
va:56)
at
7)
at
at
635)
at
..java:438)
at
at
at
java:63)
at
at
at
java:298)
at
at
at
at
..java:25)
"Lynn Orrell" <Lynn.Orrell@wiltel.com> wrote in message
news:c807f1$5tt$1@eclipse.org...
> All -
> Thanks!
> Lynn
| Re: Problem with Cheetah04 [message #158646 is a reply to message #158639] |
Thu, 13 May 2004 13:26   |
There was a mismatch between jdt.core and jdt.ui in this build. This has
been corrected. Please take I200405131200 (which is being build right now).
Jerome
news:c80914$7t5$1@eclipse.org...
> file.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> Loader.java:207)
> at
> at
> at
> at
> assLoader.java:59)
> at
> oader.java:368)
> at
> .java:399)
> at
> at
> at
> Loader.java:207)
> at
> at
> at
> at
> assLoader.java:59)
> at
> oader.java:368)
> at
> .java:399)
> at
> at
> at
> at
> Viewer.java:172)
> at
> at
> ditor.java:2221)
> at
> r.java:53)
> at
> at
> or.java:3264)
> at
> at
> :607)
> at
> a:710)
> at
> va:56)
> at
> 7)
> at
> at
> 635)
> at
> .java:438)
> at
> at
> at
> at
> at
> java:63)
> at
> at
> at
> java:298)
> at
> at
> at
> at
> .java:25)
> !STACK 0
> at
> at
> :211)
> at
> at
> at
> :607)
> at
> ava:99)
> at
> at
> at
> :607)
> at
> ava:99)
> at
> at
> a:710)
> at
> va:56)
> at
> 7)
> at
> at
> 635)
> at
> .java:438)
> at
> at
> at
> at
> at
> java:63)
> at
> at
> at
> java:298)
> at
> at
> at
> at
> .java:25)
> > All -
JDK1.5
> > Thanks!
> > Lynn
| Re: Problem with Cheetah04 [message #158654 is a reply to message #158646] |
Thu, 13 May 2004 16:00   |
After downloading and freshly installing I200405131200 + Cheetah04 I still
have the same problem. In fact, the stack traces are identical. Any other
ideas?
-Lynn
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:c80ant$a8j$1@eclipse.org...
now).
> Jerome
> > file.
> > !STACK 0
> > at
> > at
> > Loader.java:207)
> > at
> > at
> > at
> > at
> > assLoader.java:59)
> > at
> > oader.java:368)
> > at
> > .java:399)
> > at
> > at
> > at
> > Loader.java:207)
> > at
> > at
> > at
> > at
> > assLoader.java:59)
> > at
> > oader.java:368)
> > at
> > .java:399)
> > at
> > at
> > at
> > at
> > Viewer.java:172)
> > at
> > at
> > ditor.java:2221)
> > at
> > r.java:53)
> > at
> > at
> > or.java:3264)
> > at
> > at
> > :607)
> > at
> > at
> > a:710)
> > at
> > va:56)
> > at
> > 7)
> > at
> > at
> > at
> > 635)
> > at
> > .java:438)
> > at
> > at
> > at
> > at
> > at
> > at
> > java:63)
> > at
> > at
> > at
> > at
> > java:298)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> > .java:25)
> > !STACK 0
> > at
> > at
> > :211)
> > at
> > at
> > at
> > :607)
> > at
> > ava:99)
> > at
> > at
> > at
> > :607)
> > at
> > ava:99)
> > at
> > at
> > at
> > a:710)
> > at
> > va:56)
> > at
> > 7)
> > at
> > at
> > at
> > 635)
> > at
> > .java:438)
> > at
> > at
> > at
> > at
> > at
> > at
> > java:63)
> > at
> > at
> > at
> > at
> > java:298)
> > at
> > at
> > at
> > at
> > .java:25)
> > > All -
installed
> JDK1.5
error
> > > Thanks!
> > > Lynn
| Re: Problem with Cheetah04 [message #158733 is a reply to message #158654] |
Fri, 14 May 2004 05:15   |
Ignore previous comments. Cheetah04 is aging a little bit, and it is now in
trouble with latest API changes which occurred in the 3.0 end plan. I will
soon repost a Cheetah update based on latest Eclipse drop.
news:c80jmt$l76$1@eclipse.org...
other
> ideas?
> -Lynn
> now).
> > Jerome
log
> > > file.
> > > !STACK 0
> > > at
> > > at
> > > Loader.java:207)
> > > at
> > > at
> > > at
> > > at
> > > assLoader.java:59)
> > > at
> > > oader.java:368)
> > > at
> > > .java:399)
> > > at
> > > at
> > > at
> > > Loader.java:207)
> > > at
> > > at
> > > at
> > > at
> > > assLoader.java:59)
> > > at
> > > oader.java:368)
> > > at
> > > .java:399)
> > > at
> > > at
> > > at
> > > at
> > > Viewer.java:172)
> > > at
> > > at
> > > ditor.java:2221)
> > > at
> > > r.java:53)
> > > at
> > > at
> > > or.java:3264)
> > > at
> > > at
> > > :607)
> > > at
> > > at
> > > a:710)
> > > at
> > > va:56)
> > > at
> > > 7)
> > > at
> > > at
> > > at
> > > at
> > > 635)
> > > at
> > > .java:438)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > java:63)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > java:298)
> > > at
> > > at
> > > at
> > > at
> > > .java:25)
> > > !STACK 0
> > > at
> > > at
> > > :211)
> > > at
> > > at
> > > at
> > > :607)
> > > at
> > > ava:99)
> > > at
> > > at
> > > at
> > > :607)
> > > at
> > > ava:99)
> > > at
> > > at
> > > at
> > > a:710)
> > > at
> > > va:56)
> > > at
> > > 7)
> > > at
> > > at
> > > at
> > > at
> > > 635)
> > > at
> > > .java:438)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > java:63)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > java:298)
> > > at
> > > at
> > > at
> > > at
> > > .java:25)
> > > > All -
> installed
> > JDK1.5
> error
> > > > Thanks!
> > > > Lynn
| Re: Problem with Cheetah04 [message #158996 is a reply to message #158972] |
Mon, 17 May 2004 06:48  |
Philippe Mulet wrote:
> That should just work, as we keep maintaining Cheetah up to date.
> I didn't want to repost an official update until Cheetah supports new
> features, like explicit parameterization of message send and constructor
> invocations. These are now under control, so once basic testing is ok, I
> will repost.
> Expect something within today or tomorrow.
Great. I'm looking forward to the new version.
bye
Stefan Matthias Aust // "Zweifel sind der Ansporn des Denkens..." -U
FUDForum. Page generated in 0.04250 seconds
