Exception when displaying a Report (as html) [message #1488134] |
Wed, 26 November 2014 05:42  |
i try to load a Report in the viewer with birt.
(the report was created with the birt designer - nothing special added, just a header and a footer, and a table in the main... no fonts were changed at all)
when i try to load the report with this code:
public void loadReport(String reportName) {
HashMap<String, Object> options = new HashMap<String, Object>();
HashMap<String, String> emitmap = new HashMap<String, String>();
options.put("SERVLET_NAME_KEY", "frameset");
options.put("FORMAT_KEY", "html");
options.put("ALLOW_PAGE", "false");
options.put("SHOW_PARAMETER_PAGE", "false");
//Report Parameters
options.put("EMITTER_OPTIONS_KEY", emitmap);
options.put("BIRT_VIEWER_LOG_LEVEL", "FINEST");
options.put("BIRT_VIEWER_LOG_DIR", Constants.getReportsFolder());
try {
WebViewer.display(reportName, browser, options);
} catch (Exception e) {
e.printStackTrace();
an empty white window gets displayed.
changing lines to:
options.put("SERVLET_NAME_KEY", "document");
// options.put("SERVLET_NAME_KEY", "frameset");
// options.put("FORMAT_KEY", "html");
shows me a stracktrace that FontFactory is missing. so i added the dependency (though i have all Birt-Update Sites already included!) so it gets correct resolved.
now i run into the next Exception this time a NPE:
- org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
AxisFault
faultCode: BirtRunReportActionHandler.__execute()
faultSubcode:
faultString: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2363)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:277)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:86)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)
at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.presentation.aggregation.layout.EngineFragment.doService(EngineFragment.java:228)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:76)
at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(BirtEngineServlet.java:116)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGet(BaseReportEngineServlet.java:185)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.service(BaseReportEngineServlet.java:116)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:386)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:684)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:229)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1086)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:428)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1020)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:370)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:494)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:971)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:1033)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:644)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:667)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.getMappedFont(FontHandler.java:213)
at org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.selectFont(FontHandler.java:172)
at org.eclipse.birt.report.engine.layout.pdf.font.FontSplitter.buildChunk(FontSplitter.java:98)
at org.eclipse.birt.report.engine.layout.pdf.font.FontSplitter.getNext(FontSplitter.java:189)
at org.eclipse.birt.report.engine.layout.pdf.text.ChunkGenerator.getNext(ChunkGenerator.java:104)
at org.eclipse.birt.report.engine.nLayout.area.impl.TextCompositor.getNextTextArea(TextCompositor.java:189)
at org.eclipse.birt.report.engine.nLayout.area.impl.TextCompositor.getNextArea(TextCompositor.java:127)
at org.eclipse.birt.report.engine.nLayout.area.impl.TextAreaLayout.layoutChildren(TextAreaLayout.java:182)
at org.eclipse.birt.report.engine.nLayout.area.impl.TextAreaLayout.layout(TextAreaLayout.java:173)
at org.eclipse.birt.report.engine.nLayout.area.impl.BlockTextArea.layout(BlockTextArea.java:74)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.startContent(LayoutEngine.java:564)
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startText(ContentEmitterAdapter.java:147)
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startLabel(ContentEmitterAdapter.java:153)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:65)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.visitContent(LayoutEngine.java:715)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.visitChildren(LayoutEngine.java:739)
at org.eclipse.birt.report.engine.nLayout.RegionLayoutEngine.layout(RegionLayoutEngine.java:31)
at org.eclipse.birt.report.engine.nLayout.area.impl.PageArea.layoutHeader(PageArea.java:457)
at org.eclipse.birt.report.engine.nLayout.area.impl.PageArea.initialize(PageArea.java:248)
at org.eclipse.birt.report.engine.nLayout.area.impl.RootArea.createNewPage(RootArea.java:147)
at org.eclipse.birt.report.engine.nLayout.area.impl.RootArea.initialize(RootArea.java:138)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.setContainer(LayoutEngine.java:368)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine._startContainer(LayoutEngine.java:456)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.startContainer(LayoutEngine.java:355)
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startPage(ContentEmitterAdapter.java:65)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:47)
at org.eclipse.birt.report.engine.layout.html.buffer.PageNode.start(PageNode.java:49)
at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBuffer.startContent(HTMLPageBuffer.java:113)
at org.eclipse.birt.report.engine.layout.html.buffer.TableBreakBuffer.startContent(TableBreakBuffer.java:287)
at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.start(HTMLLeafItemLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:139)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:269)
... 40 more
{http://xml.apache.org/axis/}hostname:pc-nwmoser
{}:org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
... 40 more
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:777)
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:755)
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:797)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:90)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
... 36 more
... 40 more
whats going on here?!
EDIT: if i change the SERVLET_NAME_KEY to preview
options.put("SERVLET_NAME_KEY", "preview");
i get displayed what i expect to get, without any warnings and errors... shouldn't this be the same on all other options???
[Updated on: Wed, 26 November 2014 06:01] by Moderator
Re: Exception when displaying a Report (as html) [message #1660887 is a reply to message #1651228] |
Mon, 09 March 2015 07:31  |
it would be great to get any information how i can handle it or how i can contribute to solve this problem.
i know this is open source but afaik B.I.R.T. is under active development and any help would be fine after nearly 4 months.
i put quite some time into birt yet, so i am willed to help (even if you need help getting a rcp version for testing.)
[Updated on: Mon, 09 March 2015 07:32] by Moderator
FUDForum. Page generated in 0.10189 seconds
