Home » Modeling » GMF (Graphical Modeling Framework) » Problems with loading a diagram_file
Problems with loading a diagram_file [message #158456] Tue, 06 November 2007 05:35
Originally posted by: lepton.gmx.net
I have created a GMF-based model editor for a meta model extending the
UML2 meta model provided by the UML2 plugin. My meta model elements are
mostly derived from the UML::Class element, because I need the
UML::Property and UML::Operations concepts. I have also created the
default primitive type imports, which are added to the domain root element
( derived from UML::Package ). My problem is the following:
I can create the desired nodes and edges, I can apply the primitive types
for attributes etcetera. If I save a created model, close the diagram and
try to load it again, some of the former created elements and some of the
former set attributes are not set or created. For example , the
connections (visual part ) between elements are not created despite the
fact that they appear in the properties view. Furthermore the type of
created UML::Properties is not set although it was correctly saved in the
xml file.
My question is , if I have to implement a custom load behavior for my
model or if there are other opportunities for solving this problem.
Any help would be appreciated!
lepton
Previous Topic:display diagram on a stand-alone application
Next Topic:GMF2 propsheet
Current Time: Fri Sep 19 07:50:41 EDT 2025
Powered by FUDForum. Page generated in 0.05137 seconds
